Behringer PMP1680S Europower 10-Channel Powered Mixer 2x800W
Brand:|Model: PMP1680S|Part # 248-6570
The new Behringer PMP1680S 10-channel powered mixer (2 x 800 watt stereo, 1,600 watt bridged mode) produces even more power than its predecessors while maintaining a famously low weight and high efficiency.
List Price$674.99
You Save33%
$449.99
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
*Domestic US orders only
Behringer HPM1000 Multi-Purpose Headphones
Qty: 1Part # 248-6248
List Price:$14.99
Part # 248-6570
  • Ultra-compact rack-mountable 2 x 800 watt stereo powered mixer (1600 watt bridged mode)
  • Revolutionary Class-D amplifier technology: enormous power, incredible sonic performance
  • Ultra-compact design at nearly half the depth and weight of conventional powered mixers
  • 10-channel mixer section features 6 mono and 2 stereo channels plus separate CD/Tape input/output
  • 2 studio-grade, 24-bit stereo FX processors with 100 awesome presets
  • FBQ Feedback Detection system instantly reveals critical frequencies for easy feedback removal
  • 8 high-quality mic preamps with switchable +48 V phantom power for condenser microphones
The new Behringer PMP 10-channel powered mixer (2 x 800 watt stereo, 1,600 watt bridged mode) produce even more power than its predecessors while maintaining a famously low weight and high efficiency. This mixer employs Class-D technology including a new switch-mode power supply, significantly reducing weight and heat. The 10-Channel PMP1680S features 8 high-quality built-in mic preamps. This model features a 24-bit FX processor and FBQ Feedback Dectection.
What is Class-D Technology?
Instead of operating relatively continuously like Class AB circuits, Class-D amps switch on and off thousands of times per second, delivering power only when needed. In other words, the amplifier is either fully on or fully off, which significantly reduces power losses from the output devices given off as heat. Less heat means these amps don't need massive heat sinks, and that means Behringer can make them lighter. Behringer's no-compromise design means the new PMP mixers will deliver full power with incredible fidelity all night long, without the need for lengthy rest cycles.
When used in conjunction with switching-mode power supplies, which don’t require huge and heavy transformers, our Class-D amplifiers provide tremendous dynamic punch and superior fidelity. The resulting speaker systems are much lighter, making them easy to transport and set up.
Massive Mono or Stunning Stereo
The latest PMP gives you the choice of 2 x 800 watts stereo, 2 x 800 watts dual mono mode (giving you a mono version of the main signal through one powered output plus a mono version of all monitor send signals through the second powered input) or 1,600 watt bridged mono sound. Whether the center of attention happens to be a folk trio, a speech, or a synth-rock band with mind-boggling stereo patches, PMP mixers can accommodate. This sonic versatility also makes it an excellent choice for churches, where vocals and stereo recordings often share face time.
Classic Control, State-of-the-Art Sound
Leave the mic preamps at home, because the quality of sound that was once only available in the studio is ready to go wherever you do. Built-in, boutique-caliber mic preamps with switchable +48 V phantom power make it possible to use either dynamic or condenser mics with the PMP Series. The gives you 8 mic inputs.
Built-in Digital Effects Processor
The new generation of PMP mixers come equipped with 24-bit FX processors, giving you 100 mind-blowing digital effect presets such as delay, chorus and reverb. Apply them to any channel, as well as to the monitors and main output. In case you’re pulling double duty as sound engineer and performer, the FX processors features a footswitch jack for remote on/off . Of course, if you have treasured outboard gear you’ve grown attached to, these mixers can integrate them into the mix while leaving out the built-in FX processor.
Changing the Channels
The PMP Series gives you excellent flexibility to accommodate whatever a performance requires. You get 8 channels for mics, guitars and other mono instruments. Stereo channels 7-10 are designed to work in pairs as stereo channels, or independently for more mono instruments. All mono channels have 3-band EQ, switchable Low cut filter for eliminating infrasonics, and Clip LEDs to indicate when the input signal is too hot.
Small, Simple, Superb
Medium-sized events call for a lightweight (28.8 lbs.), easy-to-use powered mixer. Behringer powered mixers are the most efficient, affordable mixers for the job, and are even suitable for use as pure analog mixers or as pure power amplifiers. With new technological advantages and incredible built-in features, it's easier than ever to lend exceptional sound quality to all kinds of public performances.
Specifications: • Output power (stereo mode): 300 watts RMS x 2 (8 ohms), 600 watts RMS x 2 (4 ohms), 400 watts peak x 2 (8 ohms), 800 watts peak x 2 (4 ohms) • Power output (bridged mode): 1,200 watts RMS (8 ohms), 1,600 watts peak (8 ohms) • Equalizer: 80 Hz/±15 dB Low, 2.5 kHz/±15 dB Mid, 12 kHz/±15 dB High • Power supply: 120V~,60 Hz • Power consumption: 1050 watts • Mains connector: IEC standard receptacle • Dimensions: 12-2/5" H x 18-1/10" W x 8-3/5" D (315 x 460 x 220 mm) • Weight: 21.8 lbs. (9.9 kg).
PRODUCT SPECIFICATIONS
  • Mixer TypeAnalog
  • Special FeaturesDigital Effects
  • XLR Mic Inputs6 to 9
  • BrandBehringer
  • ModelPMP1680S
  • Part Number248-6570
  • UPC705105163888
  • Product CategoryPowered Mixers
    (1 Reviews)
  • Weight25.9 lbs.
View similar products to the Behringer PMP1680S Europower 10-Channel Powered Mixer 2x800W
in the Powered Mixers product category.
