Behringer PMP1000 Europower Powered Mixer
Brand:|Model: PMP1000|Part # 248-704
The 500 watt mixer has built-in mic preamps and an FX processor, as well as enough power to drive both mains and monitors thanks to dual 250 watt onboard power amps.
Part # 248-704
  • Ultra-compact 2 x 250 watt stereo powered mixer (500 watt bridged mode)
  • Revolutionary amplifier technology: enormous power, incredible sonic performance and light weight
  • Ultra-compact design at nearly half the weight of conventional powered mixers
  • 12-channel mixer section features 4 mono and 4 stereo channels, 2 additional stereo inputs
  • Studio-grade 24-bit stereo FX processor with 100 awesome presets including reverb, chorus, flanger
  • Revolutionary FBQ Feedback Detection system reveals critical frequencies for easy feedback removal
  • 6 high-quality mic preamps with switchable +48 V phantom power for condenser microphones
If you need superior stereo sound for small club gigs, churches or speeches, but have to keep the outboard gear to a minimum, the 12-channel PMP1000 can deliver. The 500 watt mixer has built-in mic preamps and an FX processor, as well as enough power to drive both mains and monitors thanks to dual 250 watt onboard power amps.
Massive Mono or Stunning Stereo
The PMP1000 gives you the choice of 2 x 250 watt stereo, 2 x 250-Watt dual mono or 500 watt bridged mono sound. Whether the center of attention happens to be a folk trio, a speech, or a synth-rock band with mind-boggling stereo patches, the PMP1000 can accommodate. This sonic versatility also makes it an excellent choice for churches, where vocals and stereo recordings often share face time.
Classic Control, State-of-the-Art Sound
Leave the mic preamps at home, because the quality of sound that was once only available in the studio is ready to go wherever you do. Six built-in, boutique-caliber mic preamps with switchable +48 V phantom power make it possible to use either dynamic or condenser mics with the PMP1000.
Built-in Digital Effects Processor
The PMP1000 is also equipped with a 24-bit FX processor, giving you 100 mind-blowing digital effect presets such as delay, chorus and reverb. Apply them to any channel, as well as to the monitors and main output. In case you're pulling double duty as sound engineer and performer, the FX processor features a footswitch jack for remote on/off.
Changing the Channels
The PMP1000 gives you excellent flexibility to accommodate whatever a performance requires. Channels 1-4 are for mics, guitars and other mono instruments. Stereo channels 5-12 are ideal for keyboards. All mono channels have 3-band EQ, switchable Low Cut filter for eliminating unwanted infrasonics, and Clip LEDs to indicate when the input signal is too hot.
The Ins and Outs
Use the CD/TAPE IN RCA inputs to feed in external stereo signals from CD players or tape decks. The VOICE CANCELLER switch eliminates the vocals from pre-recorded music for instant karaoke applications.
CD/TAPE RCA outputs send line-level signals from the mixer to a recording device. Left and right 1/4" output connectors are there in case you need to connect more power amps. Connect your monitor power amps or active monitor speakers to the MONITOR output.
A STANDBY switch mutes all mic channels during breaks, preventing the microphones from picking up noise or interference. You can leave all faders untouched while you play a CD via the CD/TAPE inputs.
We even did our best to include a built-in personal assistant. The FBQ Feedback Detection system automatically shows you which frequencies are causing the feedback. Just touch a FBQ button and watch the red LEDs on the 7-band graphic EQ pinpoint which frequencies to adjust for optimized sound, without the feedback.
Optimized Output
The PMP1000's POWER AMP switch toggles between three operating modes: MAIN, MON and BRIDGE (the power outputs of A and B on the back panel are summed and provided at OUTPUT B). Dual mono mode uses Output A for mono Mains and Output B for monitors. This clever functionality powers both your mains and monitors without the need for any additional power amps.
  • Mixer TypeAnalog
  • Special FeaturesDigital Effects
  • XLR Mic Inputs6 to 9
  • BrandBehringer
  • ModelPMP1000
  • Part Number248-704
  • UPC4033653020961
  • Product CategoryPowered Mixers
    (3 Reviews)
  • Weight21 lbs.
View similar products to the Behringer PMP1000 Europower Powered Mixer
in the Powered Mixers product category.
