Behringer PH9 Classic 90 degree Phase Shifter Effects Pedal
Brand:|Model: PH9|Part # 248-6334
Create phase-shifting effects with different characteristics ranging from modern to vintage with Behringer's PH9 phase effect pedal.
  • Authentic and classic 90° phase shifting—from spacey warbles to mind-blowing hypnotic swirls
  • Dedicated Swirl switch for vintage and modern phaser tones
  • Blue status LED for effect on/off and battery check
  • True hard-wire bypass for ultimate signal integrity
  • Runs on 9V battery or the BEHRINGER PSU-SB DC power supply (not included)
  • High-quality components and exceptionally rugged construction ensure long life
Looking for a pedal that provides both classic and modern phase shifting, without the steep learning curve? With just a single knob and switch, the PHASER PH9 effects pedal gives you ultra-warm and bubbly phasing tones that will keep you and your audience totally mesmerized.
What Could Be Easier?
Thanks to its simple control layout, the PH9 serves up amazing 90° phase shifting with spacey warbles and mind-blowing, hypnotic swirls, with the absolute minimum amount of tweaking. The dedicated RATE control sets the speed of the effect, while the SWIRL switch alternates the phasing character between modern to vintage.
Built to Last
Designed to withstand the rigors of the road, the PH9's build quality is second to none. A status LED for effect On/Off and battery check is included, plus there is a true hard-wire bypass for the ultimate in signal integrity. You can power the PH9 with a 9V battery or our PSU-SB DC power supply (not included).
Phase One
Get on over to your authorized dealer and check out the ultra-affordable PHASER PH9. Who knew that one knob and one switch could be this hypnotizing? Behringer, that's who!
• Input connector: 1/4" TS • Input impedance: 1M ohms • Output connector: 1/4" TS • Output impedance: 1k ohm • Power supply: 9 VDC, 100mA regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/5" H x 4-2/5" W x 2-2/3" D (56 x 113 x 69 mm) • Weight: Approx. 0.53 lbs. (0.24 kg).
  • BrandBehringer
  • ModelPH9
  • Part Number248-6334
  • UPC4033653053051
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.73 lbs.
View similar products to the Behringer PH9 Classic 90 degree Phase Shifter Effects Pedal
in the Guitar & Bass Effects Pedals product category.
