Behringer PB100 Preamp / Volume Booster Stomp Box
Brand:|Model: PB100|Part # 248-6328
With the high performance features of the PB100 by Behringer you can match Piezo pickups to regular amp inputs or boost volume while playing solo parts.
  • Boost the volume and shape the sound of any instrument
  • Switch to turbo-mode when playing solos
  • Boost up piezo pickups to match regular amplifier inputs
  • Dedicated Gain, Bass, and Treble controls for awesome sound shaping
  • Status LED for effect on/off and battery check
  • Runs on 9V battery or the BEHRINGER PSU-SB DC power supply (not included)
  • First-class electronic On/Off switch for noise-free operation
Boost a solo, power up your piezo pickups or send your tube amp into overdrive with the PREAMP BOOSTER PB100.
Take it to the Limit
No matter what kind of electric instrument you're playing, there are times when you need to push your sound to the next level. Nothing gets you there like the Preamp Booster PB100. Like a dose of sonic steroids, the PB100 can push a tube amp into a beautiful state of natural break-up, make piezo pickups sound punchy and powerful, or launch a righteous guitar solo through the stratosphere.
Easy to Use
With its dedicated BASS, TREBLE and GAIN dials, the PB100 not only allows you play to louder, it also lets you add enhanced highs and lows to your sound. A super-bright LED tells you when it's activated, and the top-quality on/off switch maintains excellent signal integrity when operating in bypass mode. You can power the PB100 with either a 9V battery or our PSU-SB DC power supply (not included).
For a mighty dose of musical muscle, reach for the ultra-affordable PREAMP BOOSTER PB100.
Specifications: • Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector: 1/4" TS • Output impedance: 1k ohm • Power supply: 9V, 100mA DC regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelPB100
  • Part Number248-6328
  • UPC4033653051255
  • Product CategoryGuitar & Bass Effects Pedals
    (2 Reviews)
  • Weight0.8 lbs.
View similar products to the Behringer PB100 Preamp / Volume Booster Stomp Box
in the Guitar & Bass Effects Pedals product category.
