Behringer OD400 Ultimate Overdrive Effects Pedal
Brand:|Model: OD400|Part # 248-6314
Use the OD400 effect pedal by Behringer when you need a boost in order to overdrive a subsequent amp.
  • The ultimate overdrive pedal for fat and big overdrive sounds with incredible dynamic response
  • Dual-stage overdrive circuitry offers bigger and fuller sound with endless sustain and compression
  • Dedicated Drive, Tone, and Level controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the BEHRINGER PSU-SB DC power supply (not included)
  • First-class electronic On/Off switch for highest signal integrity in bypass mode
  • High-quality components and exceptionally rugged construction ensure long life
The warm, crunchy sound of a tube amp being pushed to its limit has become a priceless staple of rock music, and with the OVERDRIVE OD400 effects pedal, that amazing sound is always at your command.
Tone, Tone, Tone
With the OD400's dedicated DRIVE, TONE and LEVEL dials, you can give your music a slightly edgy jumpstart, or push it completely over the edge, creating a volcanic eruption of fat, juicy tone. And no matter how heavy or light you like your overdrive, this ultra-responsive stomp box respects the dynamics of your playing style. The blue LED lets you know when the OD400 is on or off. (We provide the LED as a convenience, trust us, you’ll know it’s on!) You can power your OD400 with either a 9 V battery or our PSU-SB DC power supply (not included).
If you crave the very essence of the rock n' roll sound, the OVERDRIVE OD400 is sure to satisfy. Get the sound that never goes out of style—in a box that never ceases to amaze. The OD400 is also extremely affordable.
• Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector: 1/4" TS • Output impedance: 1k ohm • Power supply: 9 VDC, 100mA DC regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelOD400
  • Part Number248-6314
  • UPC736211843579
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.733 lbs.
View similar products to the Behringer OD400 Ultimate Overdrive Effects Pedal
in the Guitar & Bass Effects Pedals product category.
