Behringer OD300 2-Mode Overdrive / Distortion Effects Pedal
Brand:|Model: OD300|Part # 248-6712
Why settle for just overdrive or distortion when you can have both? Set your tone on fire with distortion, overdrive, or a potent blend of both with the Behringer Overdrive/Distortion OD300.
ORDER TODAY
Ships in 7-10 Business Days
List Price$37.99
You Save34%
$24.99
Part # 248-6712
  • Take off with overdrive, distortion or a combination of both effects in one powerful pedal
  • This Behringer product has been designed to compete head to head with leading products on the market
  • Dedicated Level, Tone, Drive and Mode controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the Behringer PSU-SB DC power supply (not included)
  • First-class electronic On/Off switch for highest signal integrity in bypass mode
The overdrive/distortion dial on the OD300 effect pedal allows you to turn the dial all the way to the left for pure overdrive or all the way to the right for straight-ahead distortion. This gives you either an edgy modern-crunch or the classic sound of hot and bothered tubes. If you prefer to have the dial in-between, you have infinite amount of options for creating the perfect overdrive/distortion cocktail. Everything you need to create signature sound is at your fingertips with the dedicated tone, level and drive dials.
The LED tells you when this pedal is working its magic, and the top-quality on/off switch maintains excellent signal integrity in bypass mode. You can power the OD300 with either a 9V battery or the optional PSU-SB DC power supply (not included).
Designed for use with guitar, bass, and keyboards.
Specifications: • Input/Output connector: 1/4" TS • Input impedance: 500k ohms • Output impedance: 1k ohm • Power supply: 9 VDC, 100 mA, regulated; 120V~, 60 Hz • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Power consumption: 30 mA • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs (0.33 kg).
  • BrandBehringer
  • ModelOD300
  • Part Number248-6712
  • UPC736211844170
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.73 lbs.
View similar products to the Behringer OD300 2-Mode Overdrive / Distortion Effects Pedal
in the Guitar & Bass Effects Pedals product category.
