Behringer NU3000 iNUKE 3000 Watt Power Amplifier
Brand:|Model: NU3000|Part # 248-6704
The NU3000 is part of the iNUKE Series amplifiers by Behringer that has high-density Class-D technology and delivers up to 3,000 watts 4 ohms bridge mode.
OUT OF STOCK
Awaiting Updated Due Date
List Price$344.99
You Save33%
$229.99
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
*Domestic US orders only
Part # 248-6704
  • Delivers over 2 x 1,500 watts into 2 ohms, 2 x 880 watts into 4 ohms, 3,000 watts into 4 ohms (bridge mode) and weighs less than 7 lbs.
  • Ultimate reliability through revolutionary cool-running High-Density Class-D technology with "near-zero" thermal buildup
  • Ultra-efficient switch-mode power supply for noise-free audio, superior transient response and low power consumption
  • Zero-Attack limiters offer maximum output level with reliable overload protection
  • Built-in Subwoofer/Satellite crossover for perfect subwoofer operation
  • Detented and illuminated gain controls for precise level setting
Behringer has spent years fine-tuning the high-density Class-D technology that gives the iNUKE Series its oomph. By carefully selecting transistors with extremely high slew rates and optimizing other proprietary parts of our circuitry, these amps react instantly to even the most demanding electronic bass impulses. The revolutionary high-density Class-D technology combined with ultra-efficient switch-mode power supplies ensures these feather-light powerhouses will drive your rig effortlessly for many years to come.
When this amazing amplifier technology is combined with our state-of-the-art switching-mode power supplies, these amplifiers provide tremendous punch. And because they are so much more efficient than conventional designs, they run cooler and don’t require the massive heat sinks and heavy toroid transformers typically associated with their conventional counterparts.
The front panel controls and indicators provide your system’s vital signs at a glance. After pressing the Power button, the Power LED lights to show the amp is ready for action. All channels feature positive-detent Gain controls with Signal LEDs that light when a signal is present, as well as clip LEDs to indicate when the signal is distorted and you need to reduce the input signal.
The rear panel is just as elegant, with combo XLR and 1/4" TRS input connectors making the iNUKE compatible with virtually any source, balanced or unbalanced. Professional twist-lock speaker sockets are provided to ensure every drop of output power gets to your loudspeakers. The rear panel is also where you'll find the switches that enable iNUKE amps to work in either dual mono, stereo or mono bridge mode. A built-in crossover switch enables the amp to operate in biamp mode, sending low frequency content to passive subwoofers, while the high frequency output is channeled to full range loudspeakers.
Sporting massive output ratings, lightweight Class-D technology, an equally lightweight price tag, and all the amenities a professional audio engineer could ask for, Behringer iNUKE amplifiers are serious amps for the most demanding applications.
Specifications: • Output power (per channel, stereo): 315 watts RMS, 440 watts peak (8 ohms), 680 watts RMS, 880 watts peak (4 ohms), 1040 watts RMS, 1520 watts peak (2 ohms)  • Output power (bridged mono): 1250 watts RMS, 1520 watts peak (8 ohms), 2050 watts RMS, 3000 watts peak (4 ohms) • Frequency response: 20 - 20,000 Hz, +0/-1 dB • Distortion: < 0.2% • Damping factor: > 160 @ 8 ohms • Signal-to-noise ratio: > 100 dB • Power supply: 120V, 60 Hz • Dimensions: 3.5" H x 19" W x 9.8" D (89 x 483 x 248 mm) • Weight: 6.6 lbs. (3 kg).
  • Power Output (RMS Per Channel @ 8 ohms)315 Watts
  • Output Channels2
  • Weight Range< 10 lbs.
  • BrandBehringer
  • ModelNU3000
  • Part Number248-6704
  • UPC705105166384
    (5 Reviews)
  • Weight9.45 lbs.
View similar products to the Behringer NU3000 iNUKE 3000 Watt Power Amplifier
