BONUS ITEM INCLUDED
248-6702_ALT_0
248-6702_ALT_1
248-6702_ALT_2
248-6702_ALT_3
248-6702_ALT_4
248-6702_ALT_5
248-6702_ALT_6
248-6702_ALT_7
248-6702_ALT_8
Behringer NU1000DSP iNUKE 1000 Watt Power Amplifier with DSP
Brand:|Model: NU1000DSP|Part # 248-6702
The NU1000DSP is part of the iNUKE Series amplifiers by Behringer with DSP that delivers up to 1,000 watts 4 ohms bridge mode.
List Price$299.99
You Save33%
$199.99
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
Part # 248-6702
  • Delivers over 2 x 500 watts into 2 ohms, 2 x 300 watts into 4 ohms, 1,000 watts into 4 ohms (bridge mode) and weighs less than 8 lbs.
  • Ultimate reliability through revolutionary cool-running High-Density Class-D technology with "near-zero" thermal buildup
  • Ultra-efficient switch-mode power supply for noise-free audio, superior transient response and low power consumption
  • High-performance DSP and 24-bit/96 kHz converters deliver ultimate signal integrity and extreme dynamic range
  • DSP section features sophisticated delay, crossover (3 filter types, up to 48 dB/octave), EQ (8 parametric, 2 dynamic), dynamics processing and lockable security settings
  • Front panel LCD display enables setup and adjustment without PC
Behringer has spent years fine-tuning the high-density Class-D technology that gives the iNUKE Series its oomph. By carefully selecting transistors with extremely high slew rates and optimizing other proprietary parts of our circuitry, these amps react instantly to even the most demanding electronic bass impulses. The revolutionary high-density Class-D technology combined with ultra-efficient switch-mode power supplies ensures these feather-light powerhouses will drive your rig effortlessly for many years to come.
When this amazing amplifier technology is combined with our state-of-the-art switching-mode power supplies, these amplifiers provide tremendous punch. And because they are so much more efficient than conventional designs, they run cooler and don’t require the massive heat sinks and heavy toroid transformers typically associated with their conventional counterparts.
The front panel controls and indicators provide your system’s vital signs at a glance. After pressing the Power button, the Power LED lights to show the amp is ready for action. All channels feature positive-detent Gain controls with Signal LEDs that light when a signal is present, as well as clip LEDs to indicate when the signal is distorted and you need to reduce the input signal.
The rear panel is just as elegant, with combo XLR and 1/4" TRS input connectors making the iNUKE compatible with virtually any source, balanced or unbalanced. Professional twist-lock speaker sockets are provided to ensure every drop of output power gets to your loudspeakers. The rear panel is also where you'll find the switches that enable iNUKE amps to work in either dual mono, stereo or mono bridge mode. A built-in crossover switch enables the amp to operate in biamp mode, sending low frequency content to passive subwoofers, while the high frequency output is channeled to full range loudspeakers.
For sound engineers requiring high-level control capability, iNUKE DSP Series amplifiers come ready for action right out-of-the-box. The built-in DSP and 24-bit/96 kHz converters ensure the ultimate signal integrity with an extremely broad dynamic range. DSP functions include a sophisticated delay for delay-line loudspeakers, crossover, EQ (eight parametric, two dynamic), and dynamics processing with lockable security settings. A convenient front panel LCD display allows you to setup and make adjustments directly at the amplifier, without the need for a PC. All iNUKE DSP models can also be set up, controlled and monitored via the front panel USB connector.
Sporting massive output ratings, lightweight Class-D technology, an equally lightweight price tag, and all the amenities a professional audio engineer could ask for, Behringer iNUKE amplifiers are serious amps for the most demanding applications.
Specifications: • Output power (per channel, stereo): 110 watts RMS, 160 watts peak (8 ohms), 210 watts RMS, 310 watts peak (4 ohms), 380 watts RMS, 530 watts peak (2 ohms)  • Output power (bridged mono): 430 watts RMS, 620 watts peak (8 ohms), 750 watts RMS, 1050 watts peak (4 ohms) • Frequency response: 20 - 20,000 Hz, +0/-1 dB • Distortion: < 0.1% • Damping factor: > 155 @ 8 ohms • Signal-to-noise ratio: > 98 dB • Power supply: 120V, 60 Hz • Dimensions: 3.5" H x 19" W x 9.76" D (89 x 483 x 248 mm) • Weight: 6.4 lbs.
  • Power Output (RMS Per Channel @ 8 ohms)160 Watts
  • Output Channels2
  • Weight Range< 10 lbs.
  • BrandBehringer
  • ModelNU1000DSP
  • Part Number248-6702
  • UPC705105166285
    (3 Reviews)
  • Weight9.2 lbs.
View similar products to the Behringer NU1000DSP iNUKE 1000 Watt Power Amplifier with DSP
Behringer NU1000DSP iNUKE 1000 Watt Power Amplifier with DSP is rated 5.0 out of 5 by 3.
Rated 5 out of 5 by from Lots of features for the moneyBought this because of all the features for the price and the great reviews posted on the net. I'm glad I did works great
Date published: 2014-04-14
Rated 5 out of 5 by from Super ValueI'm using 2 of these amps to drive my homebuilt Electrostatic Hybrids, one stereoamp for each channel.The built in digital DSP crossover and equalizers are a dream to operate, and they, on top of every thing, also sound wonderful!
Date published: 2013-02-16
Rated 5 out of 5 by from Excellent valueImpressive amplifier. Powerful, light, and great, flexible, easy to use DSP built in. Produces a tiny bit of something resembling white noise that I'm guessing is switching noise that gets past the output filters, but who cares at this price and power level?The fan is noisy, and I've removed it for operation at moderate power levels at room temperature indoors and not mounted in a rack. The amp gets a little warm and doesn't seem to mind, but I know this will probably shorten its life. Eventually, it will go in a rack that has a quiet, central fan or blower.
Date published: 2012-02-01
  • 2016-02-09T06:35CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_248-6702, PRD, sort_mostRecent
Is there a MAC version of the control software?
Asked by: rhythmpriest
There does not appear to be a Mac version of the software at this time.
Answered by: Chrisf
Date published: 2016-01-27
Could this amp handle a 2ohm load on one of the channels and a 4ohm load on the other channel?  I would like to use one channel to power a sub woofer (@2ohms) and the other channel to power a set of tower speakers (two 8ohm speakers wired in parallel).
Asked by: JeffBeis
Yes.
Date published: 2015-08-13
Right now I have one Dayton 250 plate amp that is powering my home theater woofer. I am using the speaker level inputs on the Dayton. I am going to discontinue the Dayton but I want Use the inuke NU1000 amp. How would I do this? Thanks in advance!!
Asked by: Jannabana
Date published: 2015-05-28
I would like to use this amp for ht subwoofer.  Does it have an auto power on like plate amps, or at least a low power stand-by mode?  Or do I have to power on/off manually?
Asked by: forthebass
It does not have an "Auto on" feature.
Answered by: TomI
Date published: 2015-03-03
Can you tell me if any of the pro-amps can be used for in home audio, such as for your stereo amp?Un
Asked by: john boyr
Yes, pretty much any pro amp can be used for home audio, but you may need an unbalanced to line level converter for it to work properly.http://www.parts-express.com/rolls-mb15b-promatch-balanced-unbalanced-converter-35mm-rca-xlr--245-1062
Date published: 2015-10-02
does this amp come with a power cord
Asked by: Dave _B
Yes. The power cord is the detachable type
Answered by: TomI
  • 2016-02-09T07:03CST
  • co_hasquestionsanswers, tq_18
  • loc_en_US, sid_248-6702, PRD, sort_recentQuestionsFirst
