Behringer NOX606 6-Ch DJ Mixer w/Infinium Optical Crossfader
Brand:|Model: NOX606|Part # 248-6694
With enough inputs to handle a mic, two turntables, two CD players and a USB device (MP3 player or computer), Behringer's NOX606 is ready for anything.
Part # 248-6694
  • Premium 6-channel club DJ mixer for the most demanding turntablist, remixer and digital DJ
  • 45-mm infinium "contact-free" optical crossfader with adjustable friction and fader curve for years of use
  • Beat-syncable FX section with 2 parameter controls assignable to Mic, 1, 2, 3, 4 or Master
  • 2 mind-blowing VCFs (Voltage Controlled Filters) can be assigned to any channel or crossfader side
  • 2 independent LFOs (Low Frequency Oscillators) for awesome filter modulation
  • Built-in USB interface for recording and playback of any digital music file. Works with your PC or Mac computer—no setup or drivers required
Frequently Bought Together
BehringerNOX Series DJ Mixers are built to connect directly to your computer and take your music straight into the digital realm. In an instant, these mixers allow you to record and play any digital music file with your PC or Mac computer without the need for any special drivers! Plus we’ve included the infinium "contact-free" VCA Crossfader, our legendary XENYX mic and premium-grade phono preamps, and beat-syncable FX for years of flawless performance.
No Media Boundaries
Like the DJ mixers that started it all, the NOX Series offer RCA inputs for your turntables, tape decks and CD players. They also feature mic inputs with our exceptional XENYX mic preamps for announcements, an impromptu rap, or any other vocal nuance. But unlike the DJ mixers of yesterday, NOX Series mixers include USB connectivity so you can access your MP3 library or digitize your own creative mix, directly via your computer. If it can be clicked, spun or spoken, the NOX Series can mix it!
Calling All DJs
Whether you're throwing multiple elements into the mix, or just keeping it simple, there's a USB-ready NOX Series mixer that’s ideal for you. The NOX606 packs a whopping 6 channels. All NOX Series models feature super-smooth channel faders and the infinium "contact-free" VCA-controlled crossfader for the utmost in reliability and smooth audio performance. The user-adjustable crossfader curves let you quickly adapt to various mixing styles.
Beat-syncable FX
A useful and powerful addition to NOX Series mixers is the internal effects engine. This processor offers 12 high-quality digital effects that can be assigned to the microphone, channel 1 or 2, crossfader A or B, or the main mix. Each effect has several parameters that can be adjusted to suit your purpose. In general, the TAP button is used to beat-sync the effect to the tempo of the music by pressing it in rhythm. The INTENSITY fader usually controls the wet/dry mix of the effect (how much is blended with the unaffected signal). The FREQUENCY knob can have various assignments. In beat-sync mode (engaged by tapping the rhythm with the TAP button), it will determine the tempo multiple. It can also adjust the rate on its own, if beat-sync is not engaged or not available.
Here's a brief description of the FX available in every NOX Series mixer:
    2XCOPY: Makes a copy of the signal, which is delayed by a defined time.
    TAPE ECHO: A simulation of the echo effect that occurs between two tape reels, which has a warm, slightly decayed sound.
    ECHO: A more modern delay effect, which is very useful for juggling beats and emphasizing musical phrases.
    FLANGER: A flanger is a wave-like effect that modulates the signal.
    PHASER: A sweeping phase shifter effect. It is similar to a flanger, except that it is enharmonic, producing a more “swooshing” sound.
    LP and HP FILTER: A Low Pass filter cuts out any frequency above its parameter settings. A High Pass filter cuts out frequencies below its parameter settings.
    AUTO PAN: Automatically moves the signal from one side of the stereo image to the other.
    VOCODER: Creates a robot voice sound straight from the early days of electronic music.
    REVERB: This is a classic effect that adds space and air to the sound.
    REV REVERB: Reverse reverb.LMT+DIST: Band-limited distortion creates a tight, compressed and distorted sound to any signal.
Total Control
The NOX606 features 4-band channel EQ and level meter for MAIN output, plus a post-fader mono output to drive subwoofers. All NOX Series mixers feature extensive headphone monitoring and cueing options.
Compose. Record. Mix. Share.
Tracktion puts the fun back into the creative process, so it's included free of charge with select Behringer products. This powerful, yet easy-to-use music production software is unlike anything you've seen before, putting everything you need on your desktop, on a single-screen, without the sea of drop down and hidden menus common to most other DAWs. In addition, Tracktion doesn't limit the number of tracks you can record, or the number of effects you can use. In fact, the only limitation is your Mac or PC computer's processing power. Recording and editing couldn't be easier; simply drag, drop, cut, copy or paste. Once your magnum opus is finished, share it with other "Tracktioneers" so they can listen, collaborate and edit. Visit to register your hardware, and you'll receive a redemption code to download Tracktion at no charge.
The full-featured NOX606 was designed for the DJ who wants everything right at his/her fingertips. In addition to the beat-syncable FX processor (which is fully assignable), two VCFs (Voltage Controlled Filters) and two LFOs (Low Frequency Oscillators) can be assigned to any channel or crossfader side for mind-blowing filter and modulation effects. And if still want more, all channels feature two switchable pre-/post-fader stereo AUX sends, so you add outboard FX for unbridled creativity. Sophisticated cueing and monitoring, 4-band EQs on all line channels, and an amazing array of output options make the NOX606 the heavyweight champion of DJ club mixers. There's even a "music only" output for a secondary listening zone or for recording your sets without the microphone!
When you hook up a NOX Series DJ mixer with USB connectivity, you're adding the ultimate modern touches to your rig at a price that will leave you with money left over for lots more tunes. The superior build quality and rugged components used in these mixers mean they will serve you well for years to come.
• S/N ratio: >88 dB • Crosstalk: >70 dB • Distortion: <0.05% @ 1 kHz • Frequency response: 10 Hz - 60 kHz • Input gain adjustment: ±12 dB • Dimensions: 4.3 " H x 18.9" W x 15" D • Weight:11.9 lbs.
  • Special FeaturesBuilt In Digital Effects,USB Connectivity
  • Stereo Line Input Channels6
  • Mic Inputs2
  • BrandBehringer
  • ModelNOX606
  • Part Number248-6694
  • UPC4033653130455
  • Product CategoryDJ / Club Mixers
  • Weight15.4500 lbs.
View similar products to the Behringer NOX606 6-Ch DJ Mixer w/Infinium Optical Crossfader
in the DJ / Club Mixers product category.
