Behringer NOX202 2-Ch DJ Mixer w/Infinium Optical Crossfader
Brand:|Model: NOX202|Part # 248-6688
Behringer's NOX202 intuitive layout makes it easy to operate right out of the box. Beneath its elegant exterior lies the heart of a 2-channel DJ battle mixer complete with a beat-syncable FX section, 3-band channel EQ and full-kill filters.
Part # 248-6688
  • Premium 2-channel battle DJ mixer for the most demanding turntablist, remixer and digital DJ
  • 45-mm infinium "contact-free" optical crossfader with adjustable tension and fader curve for years of use
  • Beat-syncable FX section with 2 parameter controls assignable to Mic, 1, 2 or Master
  • Built-in USB interface for recording and playback of any digital music file. Works with your PC or Mac computer—no setup or drivers required
  • Awesome 3-band EQ with full-kill filters plus 6-segment level meters with peak hold function per channel
  • Premium phono and XENYX mic preamps for superior detail and ultimate punch
Behringer NOX Series DJ Mixers are built to connect directly to your computer and take your music straight into the digital realm. In an instant, these mixers allow you to record and play any digital music file with your PC or Mac computer without the need for any special drivers! Plus we’ve included the infinium "contact-free" VCA Crossfader, our legendary XENYX mic and premium-grade phono preamps, and beat-syncable FX for years of flawless performance.
No Media Boundaries
Like the DJ mixers that started it all, the NOX Series offer RCA inputs for your turntables, tape decks and CD players. They also feature mic inputs with our exceptional XENYX mic preamps for announcements, an impromptu rap, or any other vocal nuance. But unlike the DJ mixers of yesteryear, NOX Series mixers include USB connectivity so you can access your MP3 library or digitize your own creative mix, directly via your computer. If it can be clicked, spun or spoken, the NOX Series can mix it!
Calling All DJs
Whether you're throwing multiple elements into the mix, or just keeping it simple, there's a USB-ready NOX Series mixer that’s ideal for you. The  NOX202 has two channels. All NOX Series models feature super-smooth channel faders and the infinium "contact-free" VCA-controlled crossfader for the utmost in reliability and smooth audio performance. The user-adjustable crossfader curves let you quickly adapt to various mixing styles.
Beat-syncable FX
A useful and powerful addition to NOX Series mixers is the internal effects engine. This processor offers 12 high-quality digital effects that can be assigned to the microphone, channel 1 or 2, crossfader A or B, or the main mix. Each effect has several parameters that can be adjusted to suit your purpose. In general, the TAP button is used to beat-sync the effect to the tempo of the music by pressing it in rhythm. The INTENSITY fader usually controls the wet/dry mix of the effect (how much is blended with the unaffected signal). The FREQUENCY knob can have various assignments. In beat-sync mode (engaged by tapping the rhythm with the TAP button), it will determine the tempo multiple. It can also adjust the rate on its own, if beat-sync is not engaged or not available.
Here's a brief description of the FX available in every NOX Series mixer:
    2XCOPY: Makes a copy of the signal, which is delayed by a defined time.
    TAPE ECHO: A simulation of the echo effect that occurs between two tape reels, which has a warm, slightly decayed sound.
    ECHO: A more modern delay effect, which is very useful for juggling beats and emphasizing musical phrases.
    FLANGER: A flanger is a wave-like effect that modulates the signal.
    PHASER: A sweeping phase shifter effect. It is similar to a flanger, except that it is enharmonic, producing a more “swooshing” sound.
    LP and HP FILTER: A Low Pass filter cuts out any frequency above its parameter settings. A High Pass filter cuts out frequencies below its parameter settings.
    AUTO PAN: Automatically moves the signal from one side of the stereo image to the other.
    VOCODER: Creates a robot voice sound straight from the early days of electronic music.
    REVERB: This is a classic effect that adds space and air to the sound.
    REV REVERB: Reverse reverb.LMT+DIST: Band-limited distortion creates a tight, compressed and distorted sound to any signal.
Total Control
The NOX202 model provides superb tone control, thanks to a 3-band EQ and full-kill filters, Gain control and precise level meter per channel. All NOX Series mixers feature extensive headphone monitoring and cueing options.
Compose. Record. Mix. Share.
Tracktion puts the fun back into the creative process, so it's included free of charge with select Behringer products. This powerful, yet easy-to-use music production software is unlike anything you've seen before, putting everything you need on your desktop, on a single-screen, without the sea of drop down and hidden menus common to most other DAWs. In addition, Tracktion doesn't limit the number of tracks you can record, or the number of effects you can use. In fact, the only limitation is your Mac or PC computer's processing power. Recording and editing couldn't be easier; simply drag, drop, cut, copy or paste. Once your magnum opus is finished, share it with other "Tracktioneers" so they can listen, collaborate and edit. Visit Behringer.com to register your hardware, and you'll receive a redemption code to download Tracktion at no charge.
NOX202
If the NOX202 had a middle name it would be "easy." Beneath its exterior is a 2-channel DJ mixer complete with a beat-syncable FX section, 3-band channel EQ and full-kill filters. Premium-grade phono preamps, along with our legendary XENYX mic preamps, ensure the ultimate in signal integrity and punch. And thanks to NOX202's onboard USB audio interface you can add your MP3s to the mix with just the flick of a switch. The NOX202 is a veritable killer in its weight class!
Value
When you hook up a NOX Series DJ mixer with USB connectivity, you’re adding the ultimate modern touches to your rig at a price that will leave you with money left over for lots more tunes. The superior build quality and rugged components used in these mixers mean they will serve you well for years to come.
Specifications: • S/N ratio: >88 dB • Crosstalk: >84 dB • Distortion: <0.04% @ 1 kHz • Frequency response: 10 Hz - 80 kHz • Input gain adjustment: 46 dB • Dimensions: 3.9 " H x 10.1" W x 10.8" D • Weight: 4.8 lbs.
  • Special FeaturesBuilt In Digital Effects,Rack Mountable,USB Connectivity
  • Stereo Line Input Channels2
  • Mic Inputs1
  • BrandBehringer
  • ModelNOX202
  • Part Number248-6688
  • UPC4033653130424
  • Product CategoryDJ / Club Mixers
  • Weight3 lbs.
View similar products to the Behringer NOX202 2-Ch DJ Mixer w/Infinium Optical Crossfader
in the DJ / Club Mixers product category.
