Behringer MX882 ULTRALINK PRO 8-Ch Splitter/Mixer
Brand:|Model: MX882|Part # 248-6306
The MX882 Ultralink Pro mixer is an 8-channel splitter, mixer, level conditioner, and converter in one making it an ultra-flexible "problem solver" in signal distribution applications.
OUT OF STOCK
Due In: 2/12/2016
List Price$149.99
You Save33%
$99.99
Part # 248-6306
  • 8-In / 2-Out line mixer, 2-In / 8-Out line splitter
  • Usable as 6-In / 6-Out level matching amplifier or direct inject (DI) box
  • Each channel can operate independently in mixer or splitter mode
  • Converts levels between -10 dBV and +4 dBu
  • Extremely wide bandwidth from 5 Hz to 200 kHz for audio purity
  • 6 mono in, 6 mono out, 2 main inputs and 2 outputs
  • 4/8-segment input/output level meters for all channels
Behringer's compact signal distribution wizard has helped countless musicians and engineers solve diverse problems, whether as a splitter, line mixer or level conditioner. Regardless of your application, the MX882 keeps your signal paths short and clean. And its multiple matching amplifiers allow you to convert home-recording level to professional level and vice versa.
Specifications: • Frequency response: 5 Hz - 200 kHz, ±3 dB • S/N ratio: >95 dBu, unweighted, 22 Hz to 22 kHz • THD: 0.002% typ. @ +4 dBu, 1 kHz gain 1 • Dimensions: Approx. 1-3/4" H x 19" W x 8-1/2" D • Weight: 6.61 lbs.
PRODUCT SPECIFICATIONS
  • Mixer TypeAnalog
  • XLR Mic Inputs< 6
  • BrandBehringer
  • ModelMX882
  • Part Number248-6306
  • UPC689076112017
  • Product CategoryLine Mixers
    (2 Reviews)
  • Weight7.24 lbs.
View similar products to the Behringer MX882 ULTRALINK PRO 8-Ch Splitter/Mixer
in the Line Mixers product category.
Behringer MX882 ULTRALINK PRO 8-Ch Splitter/Mixer is rated 4.5 out of 5 by 2.
Rated 5 out of 5 by from A real "Swiss army knife"Low (No) noise, will help connect any audio device to any audio device. I'm using it for level matching, does a great job.All but two channels have XLR I/O. To be truly versatile, RCA, 1/4 and XLR on every channel would be nice. As it is, you may need to build custom cables to suit your needs.
Date published: 2009-11-11
Rated 4 out of 5 by from Perfect solution in my application.I am using this unit in splitter mode in my home theater/stereo rack system, to maintain proper levels in sending signal to secondary amps,tape decks,other room systems, and my computer sound recorder. This unit is very versatile, with balanced connections, and multiple use options. Read the on-line manual before you buy if needed. To maintain stereo sends it is necessary to use channels in pairs, panned left and right,so three panned pairs plus the direct outs, give you four adjustable stereo sends. Would work well as a simple mixer also.
Date published: 2009-02-01
  • 2016-02-06T07:10CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_248-6306, PRD, sort_mostRecent
I would like to get a picture of the back of this particular amp please.
Asked by: Staginator
The rear of this unit can be seen in the manual which can be downloaded on the product page under "Manuals and Resources".
Date published: 2014-08-25
  • 2016-02-06T08:20CST
  • loc_en_US, sid_248-6306, PRD, sort_recentQuestionsFirst
