Behringer MON800 Stereo Monitor Matrix Mixer w/Talkback Mic
Brand:|Model: MON800|Part # 248-6298
Behringer's MON800 matrix mixer features a dedicated input section with 4 selectable and mixable stereo inputs plus accurate 6-digit LED main stereo output meters for precise level indication.
Part # 248-6298
  • Ultra-compact 9.5" monitor matrix mixer for studio and stage applications
  • Dedicated input section with 4 selectable and mixable stereo inputs
  • Accurate 6-digit LED main stereo output meters for precise level indication
  • High-power phones output with dedicated Level control
  • 3 selectable stereo speaker outputs with separate Level controls for ultimate monitoring
  • Professional Mute, Dim, and Mono functions for ultimate flexibility and phase check
  • Talkback section with internal microphone and comprehensive routing options
By listening to your mix through multiple sound systems, you can craft a mix that sounds great on every system it’s played through. This monitor matrix mixer with talkback mic is also the perfect way to expand your mixing capabilities. In fact, you can even use it without a console! Just flick a switch to listen to your productions over different loudspeaker systems and mix your tracks for maximum impact.
Listen In
The MON800 features a clearly structured input section with four selectable and mixable stereo inputs, as well as a precision 6-LED output level meter. You also get a powerful headphones jack with its own volume control, plus three selectable stereo loudspeaker outputs with separate volume controls for optimal adjustment.
Ease of Operation
The sublimely useful MON800 features MUTE and DIM functions, as well as a mono switch, which is ideal for checking phase compatibility. The integrated TALKBACK section with built-in microphone provides multiple routing options. High-quality potentiometers and backlit switches give you session after session of reliable, easy-to-operate monitoring.
Connections
Recording on your home computer? Just connect a line-level signal out to the MIX IN A connectors on the MON800. Connect your main monitor speakers to the SPEAKERS OUT A section, and another pair to the B outputs. The A and B switches allow you to choose which pair of speakers you want to hear.
Monitor and Mix Your Masterpiece
If you need a simple, affordable way to bring your mixing process to a whole new level, the MON800 is for you. This valuable audio solution ensures your recordings will sound rich, whether they are played through an immense sound system, a car stereo, or your MP3 player.
Specifications: • Frequency response: 10 Hz - 80 kHz, ±3 dB • Dynamic range: 112 dB, 20 - 20 kHz • THD: 0.005% typ. @ +4 dBu • Crosstalk: -75 dB @ 1 kHz • S/N ratio: 102 dB @ +4 dBu, a-weighted • Dimensions: Approx. 1.89" H x 9.55" W x 4.72" D • Weight: Approx. 1.1 lbs.
PRODUCT SPECIFICATIONS
  • Mixer TypeAnalog
  • BrandBehringer
  • ModelMON800
  • Part Number248-6298
  • UPC4033653010894
  • Product CategoryLine Mixers
    (1 Reviews)
  • Weight3.05 lbs.
View similar products to the Behringer MON800 Stereo Monitor Matrix Mixer w/Talkback Mic
in the Line Mixers product category.
