Behringer MIX800 Ultra-Compact Karaoke Machine
Brand:|Model: MIX800|Part # 248-6684
The MIX800 by Behringer has integrated a digital echo/reverb processor in 24-bit/40 kHz resolution to assure ultimate voice enhancement, allowing you to sound your best!
List Price$104.99
You Save33%
$69.99
Part # 248-6684
  • Ultra-compact karaoke/voice processor for podcast, studio and stage applications
  • Revolutionary Voice Canceller—effectively eliminates vocals from any stereo source while retaining most music elements
  • Integrated digital echo/reverb processor for ultimate vocal enhancement
  • 2 independent mic channels with Level controls and Clip indicators for perfect level adjustment
  • Dedicated 2-band EQ for awesome vocal enhancement and sound shaping
  • Accurate 6-segment LED output meter for precise level indication
Frequently Bought Together
The revolutionary Voice Canceller inside the MIX800 karaoke machine effectively eliminates vocals from any stereo source while retaining most music elements. Behringer has also included 2 independent mic channels with level controls and clip indicators for perfect level adjustment. A dedicated 2-band EQ provides for awesome vocal enhancement and sound shaping, and there is an accurate 6-digit LED output meter for precise level indication.
Stereo Line Inputs/Outputs let you connect your favorite CD or MP3 player, tape recorder and similar equipment. Long-term reliability is guaranteed with the high-quality potentiometers and illuminated switches. Ultra low-noise audio operational amplifiers offer outstanding sound performance. In addition, all MINI Series models can be stacked on top of each other to create an ultra-compact signal processing solution.
Specifications: • Mic input connector: 1/4" stereo jack, balanced • Mic input impedance: Approx. 2k ohms balanced • Max. mic input level: -20 dBu • Audio input connector: Cinch, unbalanced • Audio input impedance: Approx. 20k ohm • Max. audio input level: 15 dBu • Audio output type: RCA connectors, unbalanced • Audio output impedance: Approx. 150 ohms • Max. output level: 15 dB • Frequency response: 10 Hz to 200 kHz, ±0/-2 dB • Dynamics: 112 dB, 20 Hz to 20 kHz • THD: 0.002% typ. @ 1 kHz • S/N ratio: 97 dBu @ 4 dBu, A-weighted • Power supply: External, 9 V~/750 mA • Dimensions: Approx. 1.9" H x 4.7" W x 9.6" D (48 x 120 x 242.6 mm) • Weight: Approx. 1.34 lbs. (0.61 kg).
  • BrandBehringer
  • ModelMIX800
  • Part Number248-6684
  • UPC689076749176
  • Product CategoryEffects Processors / DSP Modules
  • Weight2.7 lbs.
View similar products to the Behringer MIX800 Ultra-Compact Karaoke Machine
in the Effects Processors / DSP Modules product category.
