Behringer MiniFBQ FBQ800 9-Band Graphic Equalizer with FBQ
Brand:|Model: Mini FBQ800|Part # 248-6204
Behringer's MiniFBQ FBQ800 9-band equalizer can easily indicate feedback with its FBQ circuitry containing LEDs on frequency band faders that can identify high energy levels.
List Price$104.99
You Save33%
$69.99
Part # 248-6204
  • Ultra-compact 9.5" graphic equalizer for studio and stage applications
  • Additional Low Cut filter removes unwanted frequencies, e. g. floor rumble
  • Accurate 6-digit LED Input/Output meters and Level control for precise level indication
  • High-quality illuminated faders, potentiometer, and illuminated switches for long-term reliability
  • Ultra low-noise audio operational amplifiers offer outstanding sound performance
  • High-quality components and exceptionally rugged construction ensure long life
Why do I need an equalizer?
If we all lived in a perfect world, there would be no need for audio equalization. Sound systems would be perfect and would reproduce perfect signals in all their glorious perfection. Also, everyone in that perfect world would like the same amount of bass, midrange and high frequency, and there would be no such thing as feedback. But the world isn't perfect, is it? Even the best sound system can benefit from the use of a good EQ—like the MiniFBQ FBQ800.
How Does it Work?
Imagine the frequency range of the sound you hear as a highway, a very wide one with nine lanes. Each of these "lanes" represent a single octave of the sonic spectrum. The first four lanes, labeled 63 - 500 (Hz) contain the really low frequency sound content, mainly bass, bass vocals, and the kick and tom drums. The three lanes labeled 1k, 2k and 4k (Hz), make up the fundamental zone of most musical instruments and the male and female vocals. 8k and 16k cover the frequency range of cymbals, snare drums and higher pitched percussion instruments. The MiniFBQ FBQ800 allows you to control the flow of audio traffic in each of these nine lanes. When properly applied, EQ makes it possible to hear all of these frequency ranges equally, thus the term equalization.
Feedback Elimination
When a specific frequency, or range of frequencies, reaches too high a level, feedback occurs—that all-too-familiar squeal or howl you get when the mic is too close to the speaker. Basically, feedback happens when there is so much of a particular frequency that it is picked up by the mic and run through the system again. That’s why feedback typically gets louder and louder the longer it's allowed to occur. Needless to say, this kind of feedback is very undesirable.
This is where the MiniFBQ FBQ800's Feedback Detection System really works its magic. In this ingenious circuitry, LEDs on the individual faders light up when that frequency band is approaching the danger zone. All you need do is lower the illuminated slider until the LED blinks out—voilà, feedback problem solved! What once required a highly trained ear is now an activity that even a child can master.
Sonic Toolkit...
That really is the best way to describe the MiniFBQ FBQ800. With its nine frequency bands, you easily fine-tune your sound and instantly eliminate feedback. And each fader can be used to boost or cut the frequency range it controls by as much as 12 dB (and that's a lot!).
Special attention is paid to the low frequency zone. In addition to low frequency faders, the MiniFBQFBQ800 features a Low Cut filter for removing unwanted low frequencies such as floor rumble, room resonance, electrical hum, etc. This is especially handy if your system is being used for speech rather than music.
To Boost or to Cut, That is the Question
Raising and lowering specific frequency bands can improve the frequency response of any room’s acoustics. For instance, if the room you're in is "bass-heavy," lowering the 63 and 125 Hz faders can help eliminate an overall "boomy" or "muddy" sound. Likewise, gently boosting the 8 and 16k sliders can add sparkle to a somewhat "dark" mix. Are the vocals getting lost in the mix? Raising the level of the 1k slider can help bring them out.
It’s important to note that raising a single fader level is not always the best solution; it's often better to lower the bands surrounding the frequency you want to bring out, and then boost the overall volume level to achieve better headroom.
Built for Accuracy and Reliability
Speaking of headroom, MiniFBQ FBQ800's 6-digit LED Input/Output meters and level control are provided for precise level maintenance. Longterm reliability is ensured, thanks to high-quality illuminated faders and switches, and our ultra low-noise audio operational amplifiers provide outstanding sonic performance. In addition, all Mini Series components may be stacked to create an ultracompact signal processing solution.
Specifications: • Frequency response: 10 Hz - 200 kHz, -3 dB • Dynamic range: 110 dB, 10 Hz to 22 kHz • Distortion: 0.003% typ. @ 0 dBu • Crosstalk:: <80 dBu @ 1 kHz #149; S/N ratio: 10 Hz - 22 kHz, <95 dB @ 0 dBu, a-weighted • Low cut-filter: 75 Hz (12 dB/oct) • Input level control: -12 dB to +12 dB • Graphic equalizer: 9 analog stereo bands • Graphic EQ control range: ±6 dB or ± dB, switchable • Graphic EQ bandwidth: 1 oct. • Dimensions: Approx. 1-8/9" H x 9-5/9" W x 4-5/7" D • Weight: Approx. 0.86 lbs.
  • BrandBehringer
  • ModelMini FBQ800
  • Part Number248-6204
  • UPC689076750776
  • Product CategoryEqualizers
    (6 Reviews)
  • Weight2.85 lbs.
View similar products to the Behringer MiniFBQ FBQ800 9-Band Graphic Equalizer with FBQ
in the Equalizers product category.
Behringer MiniFBQ FBQ800 9-Band Graphic Equalizer with FBQ is rated 4.1667 out of 5 by 6.
Rated 3 out of 5 by from Can't modify previous review, so writing a new oneInitially I really liked this product. I was using it on my desktop at work. My equipment was:iPod Video line out -> This FBQ800 -> JDS Labs O2 headphone amp -> Sennheiser Momentum headphones.My iPod died recently, so I decided to step up the sound quality, and bought a Fiio X5. Same setup as above, only with the Fiio X5 instead of the iPod Video. This eq doesn't seem to like the stronger line-out of the Fiio. I hear lots of artifacts, especially around female vocal freqs, and the noise floor is noticeably raised (albeit not horrible), despite being nowhere near clipping. I know it's the Behringer because I can bypass it and connect the Fiio directly to the headphone amp, and the artifacts and noise floor disappear.Bottom line: It's still a decent product for a lower voltage input, but higher voltage inputs should look at a different product.
Date published: 2015-02-28
Rated 5 out of 5 by from Does what you'd expect it to doWorks, low insertion loss, low noise. Build quality leaves some to be desired, but for this price, it's more than acceptable.
Date published: 2015-02-12
Rated 3 out of 5 by from Not for critical listeningLots of knobs and buttons for the money. Seems well built internally, at least as far as circuit board and physical assembly. Flattens the sound stage and reduces the dynamics when all controls are switched out and sliders are set flat. No hardwire bypass - switched out is not really out of the signal path. Probably OK for MP3s or DJ work but not a serious studio, critical listening or system equalization piece. Disappointing performance, too new to comment on reliability.
Date published: 2009-10-12
Rated 4 out of 5 by from DOES A GREAT JOBUsed it for my portable DJ service the same day it arrived-made those speakers thump the bass. Very nice for the price!
Rated 5 out of 5 by from great compact equalizerno insertion loss/no distortion
Date published: 2009-03-27
Rated 5 out of 5 by from Budget? Buy It.This EQ is a great deal for the money if you ask me. It has alot of features that I really like. I use it to EQ my recording monitors and it is definately useful for that. It's not a dual 31-band, but it's not $300 bucks either. 9-band for $50, with all the features, it's a deal.
Date published: 2009-03-09
  • 2016-02-12T06:31CST
  • co_hasreviews, tv_0, tr_6
  • loc_en_US, sid_248-6204, PRD, sort_mostRecent
Is there a channel balance control?
Asked by: Diabelli
This unit does not have balance control.
Date published: 2015-04-14
Where in the chain does this go? Between source and amp? ---or between amp and spkrs? Is there a channel balance control?
Asked by: Diabelli
Typically the EQ is after the source and before the amp.
Answered by: TomI
Date published: 2015-04-13
Hello, I have a few questions., does this have a cable to plug it into the standard USA wall power outlet? Also Does this unit have RCA inputs and outputs and if so how many of each?
Asked by: Tuttle
Yes this does come with a wall adapter for power. The unit has two sets of stereo RCA's, one input and one output.
Date published: 2014-07-07
  • 2016-02-12T07:12CST
  • loc_en_US, sid_248-6204, PRD, sort_recentQuestionsFirst
