Behringer MIC200 Tube Ultragain Tube Preamp with Modeling
Brand:|Model: MIC200|Part # 248-6292
The TUBE ULTRAGAIN MIC200 is a high-end vacuum tube mic/line preamplifier with preamp modeling technology and an integrated limiter for studio, live, and hard disk recording applications.
List Price$74.99
You Save33%
$49.99
Part # 248-6292
  • Perfectly matches your studio, live and hard disk recording set-up
  • Ultra-flexible Preamp Modeling allows you to quickly optimize your recordings
  • Hand-selected 12AX7 vacuum tube with UTC technology for exceptional warmth and lowest noise
  • Ensures outstanding signal transparency when used as a high-end DI-box
  • Equipped with Behringer's sophisticated output limiter
  • Dedicated low cut filter eliminates unwanted noise, e.g. floor rumble
  • +48V phantom power, phase reverse switch and 20 dB pad for utmost flexibility
Tubes can really warm up a signal fast, giving it depth and character. Though transistors have succeeded the technology, many musicians agree that tubes deliver superior sound. Behringer's TUBE ULTRAGAIN MIC200 has 16 selectable preamp voicings designed to give anything from microphones to guitars to pianos that vintage tube vibe.
Put a Little Tube in Your Tone
The MIC200 is perfect for studio and live applications. The balanced 1/4" TRS and gold-plated XLR inputs and outputs give you maximum flexibility in either scenario. It derives its personality from a hand-selected 12AX7 tube with UTC technology for superior tube character and low-noise operation. The MIC200 is great for eliminating the "dull" sound of standard digital recorders and sound cards. And thanks to onboard +48V phantom power and 20 dB pad, the MIC200 can also add warmth to condenser microphones. When used as a high-end DI box, you get outstanding signal integrity.
Two big vintage-style knobs control gain and output. There's also a switch for phase reverse and a limiter to prevent overloading the MIC200. An 8-segment LED meter provides accurate monitoring of output levels. Select from 16 preamp voicings specially created for vocals, guitar, bass, keyboard, piano and percussion.
Vintage Sound, Modern Value
The MIC200 gives you the sound quality of a vintage tube preamp at a mere fraction of what a true relic of the 1960s would cost. At a price this low, you owe it to yourself to find out where the MIC200's real tube tone can take your sound.
Specifications: • Frequency response: MIC input <10 Hz - 47 kHz (±3 dB), Line input <10 Hz - 55 kHz (±3 dB) • Function controls: Gain variable (+26 to +60 dB), Output variable (-oo to +10 dB) • Dimensions: Approx. 2-1/2" H x 5-1/4" W x 5-1/4" D • Weight: Approx. 1.1 lbs.
  • BrandBehringer
  • ModelMIC200
  • Part Number248-6292
  • UPC689076149211
  • Product CategoryMicrophone Preamps & Channel Strips
    (2 Reviews)
  • Weight2.7 lbs.
View similar products to the Behringer MIC200 Tube Ultragain Tube Preamp with Modeling
in the Microphone Preamps & Channel Strips product category.
