Behringer iNUKE NU4-6000 6000 Watt Four Channel Power Amplifier
Brand:|Model: NU4-6000|Part # 248-6800
Sporting not just one, but four 1500 watt Class-D amplifiers in a single lightweight rack-mountable housing, an equally lightweight price tag, plus all the amenities a professional audio engineer could ask for, the Behringer iNUKE NU4-6000 is the real deal!
List Price$524.99
You Save33%
$349.99
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
*Domestic US orders only
Part # 248-6800
  • Delivers over 4 x 1500 watts into 2 ohms, 2 x 3000 watts into 4 ohms (bridge mode) and weighs less than 16 lbs.
  • Zero-Attack limiters offer maximum output level with reliable overload protection
  • Built-in Subwoofer/Satellite crossover for perfect subwoofer operation
  • Independent DC, LF and thermal overload protection on each channel
  • High-quality components and exceptionally rugged construction ensure long life
The powerful iNUKE NU4-6000 packs four 1500 watt amplifiers into the space of one. Now you can run your stereo full range mains plus two separate monitor mixes with this one exceptionally lightweight, rack-mountable powerhouse. Or, you may want to operate your subwoofers in bridge mode (3000 W) and run your mid/high packs in mono biamp mode (2 x 1500W). The highly versatile iNUKE NU4-6000 gives you options, and lots of them. Their revolutionary high-density Class-D technology combined with ultra-efficient switch-mode power supplies ensures these feather-light power amps will drive your rig effortlessly for many years to come.
Superb transient response
Behringer spent years fine-tuning the high-density Class-D technology that gives the iNUKE Series its oomph. By carefully selecting transistors with extremely high slew rates and optimizing other proprietary parts of the circuitry, these amps react instantly to even the most demanding electronic bass impulses.
When this amazing amplifier technology is combined with state-of-the-art switching-mode power supplies, these amplifiers provide tremendous punch. And because they are so much more efficient than conventional designs, they run cooler and don’t require the massive heat sinks and heavy toroid transformers typically associated with their conventional counterparts.
Sublimely simple operation
The front panel controls and indicators provide your system's vital signs at a glance. After pressing the Power button, the Power LED lights to show the amp is ready for action. All channels feature positive-detent Gain controls with Signal LEDs that light when a signal is present, as well as Clip LEDs to indicate when the signal is distorted and you need to reduce the input signal.
The rear panel is just as elegant, with combo XLR and 1/4" TRS input connectors making the NU4-6000 compatible with virtually any source, balanced or unbalanced. Professional twist-lock speaker sockets are provided to ensure every drop of output power gets to your loudspeakers. The rear panel is also where you'll find the switches that enable the NU4-6000 to work in quad mono, dual stereo, or dual mono bridge mode. A built-in crossover switch enables the amp to operate in biamp mode, sending low frequency content to passive subwoofers, while the high frequency output is channeled to full range loudspeakers.
Specifications: • Output power (per channel, four channels): 315 watts RMS, 440 watts peak (8 ohms), 680 watts RMS, 860 watts peak (4 ohms), 1040 watts RMS, 1600 watts peak (2 ohms) • Output power (per channel pair, bridge mono): 1250 watts RMS, 1600 watts peak (8 ohms), 2050 watts RMS, 3000 watts peak (4 ohms) • Frequency response: 20 - 20,000 Hz, +0/-2 dB • Distortion: < 0.2% • Signal-to-noise ratio: > 100 dB • Power supply: 120V, 60 Hz • Dimensions: 3.5" H x 19" W x 12.2" D (95 x 482 x 310 mm) • Weight: 12.4 lbs.
  • Power Output (RMS Per Channel @ 8 ohms)315 Watts
  • Output Channels4
  • Weight Range10 to 19 lbs.
  • BrandBehringer
  • ModelNU4-6000
  • Part Number248-6800
  • UPC748252143044
    (2 Reviews)
  • Weight15.6500 lbs.
View similar products to the Behringer iNUKE NU4-6000 6000 Watt Four Channel Power Amplifier
