Behringer HPS3000 High Performance Studio Headphones
Brand:|Model: HPS3000|Part # 248-740
The Behringer HPS3000 high-performance studio headphones feature superb frequency response meeting the high demands of professional studio users.
OUT OF STOCK
Due In: 2/12/2016
List Price$29.99
You Save33%
$19.99
Part # 248-740
  • Ultra-wide frequency response and dynamic range
  • High-definition bass and super-transparent highs
  • High-efficiency cobalt capsule
  • Single-sided cord with oxygen-free copper wires
  • Optimized oval-shaped ear cups
  • Rugged headband construction
The Behringer HPS3000 high-performance studio headphones feature superb frequency response meeting the high demands of professional studio users. Additional features include a high-efficiency cobalt capsule, high dynamic headroom, single-sided oxygen-free copper cord, and optimized oval-shaped ear cups with ultra-rugged headband construction. You get ultra-wide frequency response, high-definition bass and super-transparent highs.
Specifications: • Capsule diameter: 40 mm • Frequency response: 20 Hz - 20 kHz • Max power handling: 100 mW • Impedance: 32 ohms • Sensitivity: 110 dB @ 1 kHz • Cord length: 6.6 ft. (2.0 m) • Connector: 1/4" TRS stereo plug.
  • Fit StyleOver-the-Ear
  • Type or Typical UseProfessional / DJ
  • ColorSilver
  • BrandBehringer
  • ModelHPS3000
  • Part Number248-740
  • UPC689076359665
  • Product CategoryHeadphones
    (8 Reviews)
  • Weight1 lbs.
View similar products to the Behringer HPS3000 High Performance Studio Headphones
in the Headphones product category.
Behringer HPS3000 High Performance Studio Headphones is rated 4.0 out of 5 by 8.
Rated 4 out of 5 by from Very good quality for cheap priceI used some that a friend purchased and loved them
Date published: 2015-03-15
Rated 4 out of 5 by from Sounds Great but a little fragile.I use these for live recording monitoring and home editing. They have a great neutral sound and are fully enclosed and seal well. The only downside is they are a bit fragile. I have had two break off at the headband joints. But they are cheap so I'm here to order another one.
Date published: 2014-06-17
Rated 4 out of 5 by from Good sound, high isolation, Great price.I needed some headphones for my PA board over at Church. Needed to have high isolation and sound fairly neutral. Saw these on the shelf and decided to give them a try. Really pretty good! The cable is a bit flimsy, and for long term strength I have no clue. But I was impressed enough to buy two more pair; one for my video editing station and one for the camera. And being inexpensive, I don't have to worry about them growing legs and walking away.
Date published: 2013-09-25
Rated 5 out of 5 by from Wide Range IndeedI got two of these for monitoring mixers for recording and live sound. I tested them initially with a few choice CDs and found the range to be as advertised -- very wide, both frequency and dynamics. Unlike other work phones I've been using these reproduced the highs and lows on par with good speakers. What comes out of these sounds like what comes out of my PA, making them better than I'd expected for my purposes. As noted, the 3mm to 1/4" adapter screws on, handy but a potential problem if you're not expecting it. Also, an extension cable is a good idea:
Date published: 2013-07-16
Rated 4 out of 5 by from Long term 2nd reviewI've had these for some time now and they sounded even better after fully breaking in. Still not perfect, but for $21, really good.I discovered a pretty bad design flaw with these and wanted to share a warning because I've ruined my set.If you screw the 1/4 adapter on the end, be sure not to make it tight at all. It holds on snugly even with a normal hand tightening.I tried to remove my adapter the other day and it turned out that I was turning the internal bits under the black rubber plastic. By the time I realized what had happened, it was too late. I had twisted the internal wires and I've shorted out / ruined my pair. I had to use vise grips to hold the base to remove the adapter. After messing around with it, I noticed that it holds a strong grip with very little tightening force.So, if you think you will want to change the adapter out more then once, be sure to use a very light hand tighten on the screw on style adapter.
Date published: 2012-03-15
Rated 4 out of 5 by from Good spare cans, great for computer use.My fist review seems to have been censored, so I'm trying again.I needed some headphones for my computer to replace a pair that had shorted out. I have been eyeballing these for awhile and added them to my last order to tip the scales for free shipping. :)Value is high, they produce some nice full range sound, but they have a few flaws in music production. When compared to more expensive headphones, they just are missing out on clarity across the whole frequency range. Bass does some a tad boomy compared to my other headphones and speakers, but not bad, just not as tight as I'm used too.The cord is only 2 meters, it could stand to be a little longer as it has it doesn't have any room to spare from the back of my computer to my chair.They do look a little cheap, but results are the most important. They are very light, but this makes them nice to wear.I recommend these for a 2nd set, but not as a 1st overall great pair of headphones.
Date published: 2010-11-17
  • 2016-02-06T07:08CST
  • co_hasreviews, tv_0, tr_8
  • loc_en_US, sid_248-740, PRD, sort_mostRecent
