Behringer HF300 Ultimate High-Band Flanger Effects Pedal
Brand:|Model: HF300|Part # 248-6244
The HD300 effects pedal pushes your sound to the extreme by producing crushing, bottom-heavy distortion for modern metal and hard rock.
  • Experience a complete new flanging sound that takes your guitar and keyboard to a new level
  • Dedicated Resonance, Rate, Depth and Manual controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the BEHRINGER PSU-SB DC power supply (not included)
  • First-class electronic On/Off switch for highest signal integrity in bypass mode
  • High-quality components and exceptionally rugged construction ensure long life
If the sound of a traditional flanger isn't quite wild enough for your latest sojourn into musical mayhem, let the HI BAND FLANGER HF300 catapult your performance to an even higher plane.
Simply Stunning
This one-of-a-kind effects pedal literally takes your playing to a higher level, a higher octave to be more precise. Every type of flanging sound is available, from a gently purring kitten, to the sound of a fighter jet shrieking past you on the flight deck of an aircraft carrier!  And since the HF300's effect is generated a full octave higher than normal, you get the brightest, cleanest flange ever.
Ease of Use
Just twist the dedicated MANUAL, DEPTH, RATE and RES(onance) dials to reach mind-warping new highs in far-out flange. The blue status LED tells you when the HF300 is activated, and the top-quality on/off switch maintains superior signal integrity in bypass mode.  You can power this bizarre little box with a 9V battery or our PSU-SB DC power supply (not included).
Value
With the HIGH BAND FLANGER HF300 in your rig, getting this high has never sounded so good—and best of all, it's totally legal and ultra-affordable!
Specifications: • Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector: 1/4" TS • Output impedance: 1k ohm • Power supply: 9 VDC, 100mA DC regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelHF300
  • Part Number248-6244
  • UPC4033653052689
  • Product CategoryGuitar & Bass Effects Pedals
    (1 Reviews)
  • Weight0.85 lbs.
View similar products to the Behringer HF300 Ultimate High-Band Flanger Effects Pedal
in the Guitar & Bass Effects Pedals product category.
