Behringer HD300 Heavy Metal Distortion Effects Pedal
Brand:|Model: HD300|Part # 248-6240
The HD300 effects pedal pushes your sound to the extreme by producing crushing, bottom-heavy distortion for modern metal and hard rock.
List Price$37.99
You Save34%
Part # 248-6240
  • Dedicated Gain Boost, Distortion, Tone, Bottom and Level controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the BEHRINGER PSU-SB DC power supply (not included)
  • First-class electronic On/Off switch for highest signal integrity in bypass mode
  • High-quality components and exceptionally rugged construction ensure long life
When you're ready to go beyond the boundaries of brutality, you have to throw some serious weight to get the job done. That's when you break out the HEAVY DISTORTION HD300.
Outrageous Distortion
In addition to providing loads of devastating distortion, this little sonic warhead allows you crank up the bottom-end and the gain, to lay waste to everything in your path.
Just Turn a Few Knobs
With its dedicated GAIN BOOST, DISTORTION, TONE, BOTTOM and LEVEL control, you can dial in a trademark sound all your own. The blue status LED tells you when this pedal is activated, and the rock-solid on/off switch maintains outstanding signal integrity in bypass mode. You can power this behemoth with a 9V battery or a PSU-SB DC power supply (not included).
No need to put it on layaway, the HD300 is so affordable that you'll just take it home.
Specifications: • Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector: 1/4" TS • Output impedance: 1k ohm • Power supply: 9 VDC, 100mA DC regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelHD300
  • Part Number248-6240
  • UPC736211843777
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.73 lbs.
View similar products to the Behringer HD300 Heavy Metal Distortion Effects Pedal
in the Guitar & Bass Effects Pedals product category.
