Behringer HA4700 High-Power 4-Ch Headphone Amp System
Brand:|Model: HA4700|Part # 248-6234
The HA4700 by Behringer offers four high-power amplifiers that can now drive loads down to 8 ohms and offers improved sound performance and comprehensive new signal routing and mixing functions, which no other headphone amplifier can match.
List Price$194.99
You Save33%
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
*Domestic US orders only
Part # 248-6234
  • Professional, multi-purpose headphones amplifier system for stage and studio applications
  • Highest sonic quality with virtually all types of headphones >8 Ohms even at maximum volume
  • Each input/aux section can be separately set to capture individual demands for more me mixing
  • Stereo aux input for each channel allows you to mix in any instrument or sound source
  • Ultra-musical high and low EQ per channel for perfect sound adaptation
  • Output level control with accurate 8-digit LED output meter per channel
  • Left & right mute switches for each channel allow two different mixes in mono mode
An articulate headphone mix can make a tremendous difference to the outcome of a recording session. The four-channel BEHRINGER HA4700 features superior performance, routing and mixing functions to accommodate the most discerning set of ears. When a conditioned mix has to reach multiple listeners, the HA4700 delivers in style.
Altogether Now
The HA4700 offers four high-power amplifiers that can drive loads down to 8 ohms. Each amplifier features its own two-band EQ, 8-digit LED output meter, left and right MUTE switches, a ST./2-CH switch to toggle between stereo or double mono, and a 1/4" stereo AUX input to mix in any instrument or sound source. The front panel gives you one PHONES OUT 1/4" jack per channel. A MAIN section features a 5-segment LED output meter, DIRECT IN 1/4" jack and MASTER LEVEL dial.
On the back panel you'll find two additional 1/4" outputs per channel. That means up to 12 pairs of headphones can listen to four separate mixes at once. The back panel also features stereo 1/4" and XLR inputs and outputs so you can connect multiple HA4700 units for even greater listening capacity. Meanwhile, ultra low-noise 4580 operational amplifiers deliver outstanding audio quality.
Great Sound, Great Value
When a recording session calls for everyone's heads and ears to be in the game, the HA4700 is essential. Hearing is believing.
Specifications: • Frequency response: 10 Hz to 150 kHz, ±3 dB • Noise: 22 Hz to 22 kHz, >90 dB @ 0 dBu • Dynamic range: 22 kHz to 22 kHz: 110 dB • Distortion: 0.006% typ. @ +4 dBu, 1 kHz, gain 1 • Dimensions: Approx. 1-3/4" H x 19" W x 8-1/2" D • Weight: Approx. 5.08 lbs.
  • BrandBehringer
  • ModelHA4700
  • Part Number248-6234
  • UPC705105159881
  • Product CategoryHeadphone Amplifiers
    (3 Reviews)
  • Weight7.5 lbs.
View similar products to the Behringer HA4700 High-Power 4-Ch Headphone Amp System
in the Headphone Amplifiers product category.
