Behringer GDI21 V-Tone Guitar Amp/Modeler/Preamp/DI Box
Brand:|Model: GDI21|Part # 248-6220
Create the most in-demand tube amp sounds or come up with your own! Our authentic V-TONE modeling technology recreates 3 classic guitar amps, 3 gain modes and 3 mic placements for a total of 27 configurations.
- Order Soon - Only 3 Left In Stock
List Price$44.99
You Save33%
$29.99
Part # 248-6220
  • Analog guitar modeling preamp/stompbox with DI recording output
  • Precise level and drive control plus musical 2-band EQ for ultimate sound
  • Output available on 1/4" TS or balanced, gold-plated XLR connectors
  • Ground lift switch eliminates typical ground loop problems
  • Runs on 9V battery or the BEHRINGER PSU-SB DC power supply (not included)
  • High-quality components and exceptionally rugged construction ensure long life
Our authentic V-TONE modeling technology recreates three of the most sought-after classic guitar amps, with three gain modes and three mic placements for a total of 27 possible configurations. You get a truckload of great amps in one convenient stomp box, allowing you to go from clean or crunch to super-fat distortion in a flash.
Extremely User-Friendly
Operation is simple; just choose the type of amp, from the smooth Calif (Californian), the bright, punchy TWED (Tweed), or the BRIT (British) with its incredible sustain and aggressive mids. Then select the gain mode, CLN (clean), HOT or HI G (high gain). Lastly, choose the mic placement from the three available selections. This feature is a BEHRINGER exclusive, allowing you to place the "virtual mic" in any of three positions:
 (OFF X)—At the edge of the speaker cone, producing a smoother, softer sound with less midrange content
(CNTR)—Positioned at the center of the cone, for more upper mids and beefy low-end
(CLSIC)—Slightly in front of the cabinet, for high midrange content with tons of definition
It’s a Tone Thing
Also included is a dedicated Drive control, for adjusting the amount of gain. This control effectively mimics the amount of push applied to the output stage of a tube amplifier, from a gentle nudge to full-out, tube-melting overdrive. Further tone shaping is provided by a highly musical 2-band EQ.
Versatility
The GDI21 can be used for direct recording output, with speaker simulation or, when used in bypass mode, as a superb active DI box. A 1/4" output jack is provided for connecting to your amp and the gold-plated, balanced XLR connector will link you cleanly to the front of house console. Ground loop problems are nonexistent, thanks to the onboard ground lift switch.
Value
Whether you use it on the stage or for recording, the BEHRINGER V-Tone Guitar GDI21 is the ultimate choice for musicians seeking an extremely versatile array of time-tested, classic tones. With the GDI21, you get the sound of three classic guitar amps and a superb DI box, all for the price of a single stomp box!
Specifications: • Input connector: 1/4" TS • Input impedance: 1M ohm • Output connector: 1/4" TS • Output impedance: 1k ohm • Balanced output connector: XLR • Balanced output impedance: 200 ohms • Power supply: 9 V, 50mA DC regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: 5" x 3-9/10" x 2" • Weight: Approx. 460 g.
  • BrandBehringer
  • ModelGDI21
  • Part Number248-6220
  • UPC689076426152
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight1.2 lbs.
View similar products to the Behringer GDI21 V-Tone Guitar Amp/Modeler/Preamp/DI Box
in the Guitar & Bass Effects Pedals product category.
