Behringer FEX800 Minifex 24-Bit Stereo Multi-FX Processor
Brand:|Model: FEX800|Part # 248-6214
The FEX800 by Behringer has 16 awesome FX presets in 24-bit/48 kHz resolution which include reverb, delay, chorus, flanger, phaser, rotary speaker, pitch shifter and multi-effects.
List Price$104.99
You Save33%
$69.99
Part # 248-6214
  • Ultra-compact 9.5" stereo multi-effects processor for studio and stage applications
  • 16 awesome FX presets in 24-bit/48 kHz resolution
  • Intuitive FX Preset control with LEDs indicating the selected program
  • Versatile Edit and Tap/Select functions to control a wide range of FX parameters
  • Stereo Input Level control with accurate 6-digit LED Input meter for precise level indication
  • Dedicated Mix Balance and Output Level controls for perfect effects level adjustment
  • Additional footswitch connector for easy FX on/off control
If you need a dose of digital magic to add to your sound, tap into the BEHRINGER MINIFEX FEX800. This cool, compact member of our MINI family is waiting to bring a whole new dimension to your sound.
Get Effected
This small stereo multi-effects processor has 16 effects presets, including reverb, delay, chorus, flanger, phaser, rotary speaker, pitch shifter and multi-effects. There is an intuitive FX Preset control with LED program indication. Versatile Edit and Tap/Select functions provide control over a wide range of effects parameters.
The Ins and Outs
The FEX800 has two modes of operation: mono and stereo. It features balanced 1/4" and XLR inputs and outputs. A stereo input level control with digit LED input meter provides precise level indication. The FEX800 has dedicated mix, balance and output level controls for accurate level adjustment. If you're using the FEX800 live, an optional footswitch connector provides easy on/off switching. High-quality potentiometers, illuminated switches and low-noise audio operational amplifiers offer exceptional sound performance.
MINI Is Mighty
The FEX800 is the simple, portable and affordable way to add an exciting new dimension to your sound. And of course, all MINI Series models can be stacked to create an ultra-compact signal processing solution. Find out today why musicians, home recording enthusiasts and sound technicians love the FEX800.
Specifications: • Converter: 24-bit delta-sigma, 128X oversampling • Sampling rate: 48 kHz • Frequency response: 10 Hz - 22 kHz, -3 dB • Dynamic range: 96 dB, 10 Hz - 22 kHz • Distortion: 0.01% typ. @ 0 dB FS • Crosstalk: -75 dB @ 1 kHz • S/N ratio: 10 Hz - 22 kHz, <86 dB @ 0 dBu, a-weighted • Dimensions: Approx. 1.9" H x 4.7" W x 9.6" D • Weight: Approx. 1.46 lbs.
  • BrandBehringer
  • ModelFEX800
  • Part Number248-6214
  • UPC689076750875
  • Product CategoryEffects Processors / DSP Modules
    (1 Reviews)
  • Weight3 lbs.
View similar products to the Behringer FEX800 Minifex 24-Bit Stereo Multi-FX Processor
in the Effects Processors / DSP Modules product category.
