Behringer FBQ800 Mini 9-Band Graphic Equalizer with FBQ
Brand:|Model: FBQ800|Part # 248-6204
Behringer's MiniFBQ FBQ800 9-band equalizer can easily indicate feedback with its FBQ circuitry containing LEDs on frequency band faders that can identify high energy levels.
OUT OF STOCK
Due In: 8/5/2016
List Price$104.99
You Save33%
$69.99
Part # 248-6204
  • Ultra-compact 9.5" graphic equalizer for studio and stage applications
  • Additional Low Cut filter removes unwanted frequencies, e. g. floor rumble
  • Accurate 6-digit LED Input/Output meters and Level control for precise level indication
  • High-quality illuminated faders, potentiometer, and illuminated switches for long-term reliability
  • Ultra low-noise audio operational amplifiers offer outstanding sound performance
  • High-quality components and exceptionally rugged construction ensure long life
Why do I need an equalizer?
If we all lived in a perfect world, there would be no need for audio equalization. Sound systems would be perfect and would reproduce perfect signals in all their glorious perfection. Also, everyone in that perfect world would like the same amount of bass, midrange and high frequency, and there would be no such thing as feedback. But the world isn't perfect, is it? Even the best sound system can benefit from the use of a good EQ—like the MiniFBQ FBQ800.
How Does it Work?
Imagine the frequency range of the sound you hear as a highway, a very wide one with nine lanes. Each of these "lanes" represent a single octave of the sonic spectrum. The first four lanes, labeled 63 - 500 (Hz) contain the really low frequency sound content, mainly bass, bass vocals, and the kick and tom drums. The three lanes labeled 1k, 2k and 4k (Hz), make up the fundamental zone of most musical instruments and the male and female vocals. 8k and 16k cover the frequency range of cymbals, snare drums and higher pitched percussion instruments. The MiniFBQ FBQ800 allows you to control the flow of audio traffic in each of these nine lanes. When properly applied, EQ makes it possible to hear all of these frequency ranges equally, thus the term equalization.
Feedback Elimination
When a specific frequency, or range of frequencies, reaches too high a level, feedback occurs—that all-too-familiar squeal or howl you get when the mic is too close to the speaker. Basically, feedback happens when there is so much of a particular frequency that it is picked up by the mic and run through the system again. That’s why feedback typically gets louder and louder the longer it's allowed to occur. Needless to say, this kind of feedback is very undesirable.
This is where the MiniFBQ FBQ800's Feedback Detection System really works its magic. In this ingenious circuitry, LEDs on the individual faders light up when that frequency band is approaching the danger zone. All you need do is lower the illuminated slider until the LED blinks out—voilà, feedback problem solved! What once required a highly trained ear is now an activity that even a child can master.
Sonic Toolkit...
That really is the best way to describe the MiniFBQ FBQ800. With its nine frequency bands, you easily fine-tune your sound and instantly eliminate feedback. And each fader can be used to boost or cut the frequency range it controls by as much as 12 dB (and that's a lot!).
Special attention is paid to the low frequency zone. In addition to low frequency faders, the MiniFBQFBQ800 features a Low Cut filter for removing unwanted low frequencies such as floor rumble, room resonance, electrical hum, etc. This is especially handy if your system is being used for speech rather than music.
To Boost or to Cut, That is the Question
Raising and lowering specific frequency bands can improve the frequency response of any room’s acoustics. For instance, if the room you're in is "bass-heavy," lowering the 63 and 125 Hz faders can help eliminate an overall "boomy" or "muddy" sound. Likewise, gently boosting the 8 and 16k sliders can add sparkle to a somewhat "dark" mix. Are the vocals getting lost in the mix? Raising the level of the 1k slider can help bring them out.
It’s important to note that raising a single fader level is not always the best solution; it's often better to lower the bands surrounding the frequency you want to bring out, and then boost the overall volume level to achieve better headroom.
Built for Accuracy and Reliability
Speaking of headroom, MiniFBQ FBQ800's 6-digit LED Input/Output meters and level control are provided for precise level maintenance. Longterm reliability is ensured, thanks to high-quality illuminated faders and switches, and our ultra low-noise audio operational amplifiers provide outstanding sonic performance. In addition, all Mini Series components may be stacked to create an ultracompact signal processing solution.
Specifications: • Frequency response: 10 Hz - 200 kHz, -3 dB • Dynamic range: 110 dB, 10 Hz to 22 kHz • Distortion: 0.003% typ. @ 0 dBu • Crosstalk:: <80 dBu @ 1 kHz #149; S/N ratio: 10 Hz - 22 kHz, <95 dB @ 0 dBu, a-weighted • Low cut-filter: 75 Hz (12 dB/oct) • Input level control: -12 dB to +12 dB • Graphic equalizer: 9 analog stereo bands • Graphic EQ control range: ±6 dB or ± dB, switchable • Graphic EQ bandwidth: 1 oct. • Dimensions: Approx. 1-8/9" H x 9-5/9" W x 4-5/7" D • Weight: Approx. 0.86 lbs.
  • BrandBehringer
  • ModelFBQ800
  • Part Number248-6204
  • UPC689076750776
  • Product CategoryEqualizers
    (6 Reviews)
  • Weight2.85 lbs.
View similar products to the Behringer FBQ800 Mini 9-Band Graphic Equalizer with FBQ
in the Equalizers product category.
