Behringer F1320D 300W 12" 2-Way Powered Monitor Speaker
Brand:|Model: F1320D|Part # 248-6674
The active EUROLIVE F1320D monitor speaker by Behringer provides the perfect solution for live and playback applications on small and middle sized stages with up to 300 watts power.
List Price$404.99
You Save33%
$269.99
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
*Domestic US orders only
Part # 248-6674
  • High-power 300 watt 2-way monitor speaker system for live and playback applications
  • Exceptional sound quality, wide frequency bandwidth and dynamic range
  • Revolutionary Class-D amplifier technology: enormous power, incredible sonic performance and super-light weight
  • Adjustable feedback filter and integrated limiter for ultimate system control and speaker protection
  • Integrated sound processor for ultimate system control and speaker protection
  • Ultra-low noise Mic/Line input with Volume control and Clip LED
Since its introduction, the EUROLIVE F1220A active floor monitor has been wildly successful. Building on that legacy, Behringer is proud to present the even more powerful EUROLIVE F1320D. This 300 watt active monitor system has its own 3-band EQ and dedicated volume knob, so you not only have control of the output, but you can tweak the highs, mids and lows for a clear, true sense of your performance. And thanks to our Class-D technology, the F1320D weighs less than 40 lbs., making them easy to transport and set up. The built-in adjustable feedback filter helps eliminate annoying squeals and howls so you can crank the volume to a level where you can actually hear yourself above the raging chaos, otherwise known as your band. After all, the main reason to have a monitor is so you can hear yourself, right? The EUROLIVE F1320D helps you hear yourself better so you can perform up to your true potential.
Beauty is Much More Than Skin Deep
Inside these active monitors is the equivalent of a 2-way electronic crossover, a graphic equalizer, a parametric equalizer, a mic preamp and two power amplifiers! A long-excursion 12'' driver delivers deep, punchy low end while the 1'' compression driver, mounted in a custom-designed horn, provides ultra-wide dispersion of clean, crisp highs. These systems work together seamlessly, cranking out 300 watts of super-clean power, and here's the best part—you don't have to be a sound engineer to run it!
Class-D Amplifier Technology
Our revolutionary Class-D amplifier technology enables us to make floor monitors that weigh about the same as their passive cousins, even with a built-in 300 watt amplifier! Class-D amps are super-efficient little beauties that don't generate as much heat as their conventional counterparts, so they don't need massive heat sinks to keep them cool. We combine these powerful amplifiers with state-of-the-art switch-mode power supplies for noise-free audio, superior transient response and extremely low power consumption.
Custom-Engineered Transducers
While some manufacturers are content with putting off-the-shelf transducers in their boxes, we custom-design and build ours from scratch. We do this because the transducers (woofers and tweeters) are the part of the system you actually hear, and we want them to sound great. Our loudspeakers deliver truly impressive performance at levels that easily cut through stage clutter, even in the most demanding situations. We make our own because they have to be right—right for each application, and most importantly—right for you!
Speaking of Control...
The F1320D doesn't just sound great, it gives you instant control of your monitor, even mid-performance—something passive monitors simply cannot deliver! Need more volume? Turn the LEVEL dial until the desired volume is reached, getting too much bass or treble? Just reach down and tweak the 3-band EQ (HIGH, MID, LOW) to tailor a rich, exciting sound. We've even provided the first line of defense against feedback, a dedicated FREQUENCY dial you can adjust to eliminate troublesome mic squeals. Total control is always right at your fingertips with the EUROLIVE F1320D.
Instant PA System
You can set up an instant sound system with just one F1320D and a microphone or MP3 player. Thanks to the built-in preamp, you can connect a dynamic mic directly to the F1320D and raise and lower the volume with the Level control. Fast and easy to set up, you can be ready for "show-time" at a moment's notice. There's even a built-in 35 mm socket, so you can mount the F1320D on a standard speaker pole for use as a PA system. And if you need more coverage, chain together as many F1320Ds as you'd like via the convenient XLR or 1/4" TRS LINK OUTPUT connector.
Versatility
When is a monitor more than a monitor? When it's used as an instrument amplifier. Yes, you read that right; the F1320D can also be used as an onstage amp for keyboards, acoustic guitar, electric violin, etc. You name it—if it's got either a mic or line-level output, you can connect it to the F1320D. Need a keyboard amp and a vocal monitor, but don’t have the space on stage for both? Use one of our small-format XENYX mixers to sub-mix the Aux Sends from the main mixer with your keys, all into a single active monitor.
Awesome Sound, Unbelievable Value
The F1320D is the ideal solution for performers/emcees seeking a high-quality active monitor or portable PA system that sets up in a flash. Loaded with a slew of incredible features, but never loaded down by a heavy price tag, the F1320D is an excellent way to expand your current sound system’s capabilities without shrinking your wallet.
Specifications: • Output power LF: 160 watts RMS (8 ohms)/225 watts peak (8 ohms) • Output power HF: 40 watts RMS (8 ohms)/72 watts peak (8 ohms) • Frequency range: 60 Hz - 16 kHz (-10 dB) • Max SPL: 115 dB/ 118 dB @ 1m • Limiter: Optical • Dimensions: Approx. 14.2" H x 22.8 W x 16" D • Weight: Approx. 33.1 lbs.
  • Speaker TypeActive / Powered
  • ConfigurationStage Monitor
  • Woofer Size12"
  • BrandBehringer
  • ModelF1320D
  • Part Number248-6674
  • UPC705105163987
  • Weight42.2000 lbs.
View similar products to the Behringer F1320D 300W 12" 2-Way Powered Monitor Speaker
