Behringer EUROCOM MA6480A 240 Watt 70/100V/4 Ohm Mixing Dual Amplifier
Brand:|Model: MA6480A|Part # 247-006
The MA6480A provides 240 watts of Dual-Drive™ power with 3-band parametric equalization and two high quality microphone preamps. This unique feature combination allows the MA6480A to perform well as a powerful mixer/amp with priority paging, or as simple expansion amplifier for more complex systems.
  • Dual-Drive™ amplification - one 4 ohm channel & one 70/100V channel
  • 240 watts RMS per channel
  • Designed to interface seamlessly with other EUROCOM products
  • 21st century energy efficiency
  • Clean, simple, elegant appearance
The EUROCOM MA6480A is a professional rack-mountable power amplifier for installed sound applications in commercial settings such as hospitality, retail, fitness, business, and education. Incorporating Behringer’s exclusive Dual-Drive™ technology, the MA6480A is powered by two independent mono amplifiers: one with a high impedance output that may be set to either 70 or 100V; and the other with a standard low-impedance output. This uniquely versatile configuration enables easy installation and setup of hybrid multi-zone systems combining distributed and low-impedance speakers, making the MA6480A an innovative yet practical solution for a broad range of installed sound environments.
The MA6480A's operation is both cool and extraordinarily energy-efficient thanks to transformerless Class-D amplifiers that utilize switch-mode power supplies. The amplifiers deliver 240 watts RMS into low impedance loads down to 4 ohms, and high-Z outputs of 70 or 100V. A balance control adjusts the relative output of the two amps. Each amplifier is protected with DC and thermal overload protection, as well as by automatic limiting that prevents overload, clipping, and distortion.
The MA6480A includes two channels for balanced or unbalanced input from line-level sources or microphones, either standard or phantom powered. Both channels accept input via XLR/TRS (1/4") combination jacks. Additionally, channel 2 accepts input from a 3-pin Euroblock connector, and channel 1 accepts input from a 4-pin Euroblock connector with a control pin. Channel 1 also has a priority mode switch that selects between always-on, voice-activated, or control-pin activated. The channel 2 input can be muted whenever the channel 1 input is active. The level at which each channel is sent to the two power amplifiers is set with individual front panel level controls.
The power amplifier outputs for both high- and low-Z appear on a single 4-pin Euroblock connector. The MA6480A also includes a 5-pin Euroblock for remote control.
The MA6480A front panel includes a master level (main mix) knob that is surrounded by an indicator ring that glows yellow when the unit is powered, and flashes red at the onset of clipping. A 3-band fully parametric EQ is provided to optimize the output for any environment. Also included is an LED meter indicating the output level to the power amplifiers.
Well-suited to any installed power amp application, the EUROCOM MA6480A makes a perfect complement to the rest of the MA6000 series, providing additional power amp channels simultaneously for both high-Z and low-Z loudspeaker systems. Integrating quality, style, and power into a single Dual-Drive™ package, the MA6480A is an exceptional value for installed sound amplification.
  • Power Output (RMS @ 70V)201W to 400W
  • Weight Range10 to 19 lbs.
  • BrandBehringer
  • ModelMA6480A
  • Part Number247-006
  • UPC736211583949
  • Product CategoryPaging & Commercial 70V Mixer-Amplifiers
  • Weight15.1 lbs.
View similar products to the Behringer EUROCOM MA6480A 240 Watt 70/100V/4 Ohm Mixing Dual Amplifier
in the Paging & Commercial 70V Mixer-Amplifiers product category.
