Behringer EUROCOM MA4000M Multiple Input Commercial Rack Mixer
Brand:|Model: MA4000M|Part # 247-010
Equipped with comprehensive feature sets, easy-to-use front panels and energy efficient technologies, MA4000 products provide solutions for a wide range of installation applications, enabling you to choose the right tool for the job, anytime, anywhere. Functionality and elegant simplicity - EUROCOM.
List Price$209.99
You Save14%
$179.99
Part # 247-010
  • Designed to interface seamlessly with other EUROCOM products
  • Plenty of input/output options
  • 21st century energy efficiency
  • Clean, simple, elegant appearance
The MA4000M mixer combines a fresh and modern aesthetic design with innovative technologies which will set new standards in distributed system designs. With a focus on sustainability, the MA4000M employs high efficiency electronics, resulting in significantly lower power consumption and operating costs. Aimed at enabling LEED certified applications it also creates a vastly smaller carbon footprint than conventional products built around legacy technologies.
The versatile, multi-function MA4000M mixer is designed for integration into distributed speech and music systems in conference centers, multi-function meeting rooms, houses of worship, universities, and other such facilities, and integrates extensive signal routing, priority muting, a dedicated paging input, and wired remote volume, mute, and power control, allowing system integrators to deliver unprecedented value and performance.
Diverse Connectivity and Signal Adjustment
The MA4000M features eight Mic/Line inputs on Euroblock connectors with switchable Mic/Line and Phantom power, individual trim control, and post-trim input level LED, four balanced microphone/line XLR/TRS combination connectors with switchable Mic/Line and Phantom power also on inputs 1-4, and four dual RCA summed connectors on inputs 5-8.
Flexible Signal Routing
Inputs 1-8 can be individually assigned to Zone 2/MOH, while Aux inputs 5-8 can be individually assigned to main mix.
Dedicated Inputs
Fully adjustable dedicated paging input on 4-pin Euroblock connector accepts a telephone or paging microphone and features priority muting across all inputs.
Multiple Output Options
With the MA4000M, you get pre-master main mix output on dual RCA connectors for recording or alternate zone assignment, dual main mix outputs on 3-pin Euroblock connectors are switchable between Mic and Line level, and a Zone 2/MOH assignable output with independent gain control on dual RCA connectors.
Unique Front Panel Design
The uniquely designed opaque drop down door conceals the power switch, equalization controls, and input level controls when not in use.
Diverse User Control and Monitoring
The front panel includes auto-dimming control illumination, VU meter, positive pressure power switch, and a dual-function indicator ring surrounding the master volume control.
Remote Connectivity
Wired remote volume, mute, and power control is possible via connection on a 5-pin Euroblock connector.
PRODUCT SPECIFICATIONS
  • Mixer TypeAnalog
  • XLR Mic Inputs< 6
  • BrandBehringer
  • ModelMA4000M
  • Part Number247-010
  • UPC736211584045
  • Product CategoryCommercial Mic/Line Zone/Paging/BGM Mixers
  • Weight13.1000 lbs.
View similar products to the Behringer EUROCOM MA4000M Multiple Input Commercial Rack Mixer
in the Commercial Mic/Line Zone/Paging/BGM Mixers product category.
