Behringer EUROCOM CL208S 200 Watt Dual 8" Subwoofer
Brand:|Model: CL208S|Part # 247-092
Featuring clean lines and a unique fabric-finished wrap-around grill, the CL208S is at home in even the most elegant settings: theaters and auditoria, houses of worship, themed and sporting venues, and more. With great response and sensitivity, it is designed to excel in small to medium venues.
Part # 247-092
  • Dual 8" subwoofers provide tight, rich bass
  • Robust 200 watts RMS power handling
  • Dual professional speaker connectors (compatible with Neutrik Speakon® connectors) and 4-position terminal strip
  • 4 ohm impedance for simple integration
  • Powder coated steel grill wrapped with acoustically transparent fabric and foam, matching cabinet color
Frequently Bought Together
The CL208S achieves fully professional performance and reliability with newly-designed components whose frequency response, sensitivity, and power handling are all custom tailored for CL Series loudspeakers. Behringer maintains complete control over quality and sonic character by manufacturing all CL Series components—starting with the pulp used for cone fabrication—in their own factories.
Featuring dual 8" woofers with 200 watt long-term power handling, the CL208S accurately reproduces even the most demanding low-end material for a clean, full sound. A built-in passive crossover maximizes flexibility by band-splitting the output of a single amplifier channel to power both the CL208S and a full-range loudspeaker.
All CL Series loudspeakers are constructed of durable laminated birch plywood. All models have metric threaded inserts for safe suspension using a variety of optional brackets and forged eyebolts.
Superior Sonic Performance
The CL208S delivers exceptional sound quality, wide frequency bandwidth and dynamic range, featuring two 8" low frequency drivers rated at 100 watts each with a 4 ohm overall system impedance.
Meticulous Construction
The entire CL Series boasts internally braced, acoustically inert laminated Baltic birch plywood enclosures.
Flexible Modular Implementation
The modular design of the CL208S allows deployment individually, in pairs, or in larger low-frequency arrays, making it simple to tailor your system to the specific requirements of the venue.
Elegant Style
Created in a subdued, non-descript, visually appealing style with a powder coated perforated wrap-around steel grill and acoustically transparent foam attached to match cabinet color, CL Series loudspeakers are available in black or white (subwoofers are black only).
Diverse Rigging Options
The CL208S has sixteen (16) M10 threaded rigging points to facilitate secure installation while remaining adaptable to the needs of the installer.
The CL208S subwoofer system from Behringer is a powerful and versatile sound reinforcement loudspeaker designed for a variety of professional fixed installation applications in such venues as houses of worship, auditoriums, clubs and discotheques, sports venues, and theaters. Every aspect of the CL208S has been thought through to maximize value and convenience for both the installer and the end user. The result is an attractive, durable, installation-ready loudspeaker system that will deliver top-notch sound day-after-day for years to come.
Specifications:  • Frequency range: 41 - 200 Hz (-10 dB); 46 - 150 Hz (±3 dB) • Nominal impedance: 4 ohms • Sensitivity (1W/1m half space): 94 dB • Crossover frequency: 200 Hz (bypassable) • Power handling (RMS, IEC passive): 200 watts @ 28.3 V • Maximum SPL: 117 dB (continuous); 123 dB (peak) • Dimensions: 11.3" H x 25.6" W x 14.6" D (286 x 650 x 371 mm) • Weight: 45 lbs. (20.4 kg).
  • Input Rating4 ohm
  • Woofer Diameter8"
  • ConfigurationSubwoofer
  • ColorBlack
  • BrandBehringer
  • ModelCL208S
  • Part Number247-092
  • UPC736211839176
  • Weight53.8000 lbs.
View similar products to the Behringer EUROCOM CL208S 200 Watt Dual 8" Subwoofer
