Behringer EUROCOM CL208-WH Compact 2-Way Dual 8" 200W 4 Ohm Loudspeaker - White
Brand:|Model: CL208-WH|Part # 247-062
Featuring clean lines and a unique fabric-finished wrap-around grille, the CL208-WH is at home in even the most elegant settings: theaters and auditoria, houses of worship, themed and sporting venues, and more. With great response and sensitivity, it is designed to excel in small to medium venues.
Part # 247-062
  • Dual 8" woofers provide tight, punchy bass
  • Constant directivity 90° x 70° rotatable waveguide with 1.35" high-frequency transducer for crisp, clear highs
  • Professional speaker connector (compatible with Neutrik Speakon® connectors) and 4-position terminal strip
  • 4 ohm impedance for simple integration
  • Powder coated steel grille wrapped with acoustically transparent fabric and foam, matching cabinet color
Thanks to their precision-engineered rotatable waveguides and computer-modeled transducers, CL Series loudspeakers deliver superior sonic performance. The CL208-WH features two 8" low frequency drivers and a 1.35" high frequency compression driver, two available dispersion patterns, and is designed to blend into virtually any environment. The refined aesthetic design compliments even the most sophisticated interior spaces.
CL Series loudspeakers are constructed of durable laminated birch plywood and finished in either black or white. All models have metric threaded inserts for safe suspension using a variety of optional brackets and forged eyebolts. Designed for arrayed applications, all models (except subwoofers) are trapezoidal in shape and may be deployed in both vertical and horizontal orientations.
Superior Sonic Performance
The CL208-WH delivers exceptional sound quality, wide frequency bandwidth and dynamic range, featuring two 8" low frequency drivers rated at 150 watts and a 1.35" high frequency compression driver rated at 30 watts RMS fitted to the high frequency waveguide.
Focused Projection
The 90° x 70° high frequency horn can be rotated in the field, allowing you to tailor your sound to fit virtually any venue or loudspeaker placement situation.
Meticulous Construction
The entire CL Series boasts internally braced, acoustically inert trapezoidal laminated birch plywood enclosures with 15° trapezoidal angles, designed for arrayed applications.
Elegant Style
Created in a subdued, non-descript, visually appealing style with a powder coated perforated wrap-around steel grille and acoustically transparent foam attached to match cabinet color, CL Series loudspeakers are available in black or white.
Diverse Rigging Options
The CL208-WH has fourteen (14) M10 threaded rigging points and four (4) M6 threaded inserts to accommodate an OmniMount™ 30-style bolt pattern.
The CL208-WH two-way compact trapezoidal loudspeaker system from Behringer is a powerful and versatile sound reinforcement loudspeaker designed for a variety of professional fixed installation applications in such venues as houses of worship, auditoriums, clubs, sports venues, and theaters. Every aspect of the CL208-WH has been thought through to maximize value and convenience for both the installer and the end user. The result is an attractive, durable, installation-ready loudspeaker system that will deliver top-notch sound day-after-day for years to come.
Specifications:  • Frequency range: 49 - 20,000 Hz (-10 dB); 55 - 15,000 Hz (±3 dB) • Nominal impedance: 4 ohms • Directivity factor (Q): 7.5 • Directivity index (DI): 8.8 dB • Sensitivity (1W/1m half space): 91 dB • Crossover frequency: 2500 Hz • Power handling (RMS, IEC passive): 200 watts @ 28.3 V • Maximum SPL: 114 dB (continuous); 120 dB (peak) • Dimensions: 28.4" H x 10.2" W x 11.9" D (720 x 260 x 302 mm) • Weight: 32.4 lbs. (14.7 kg).
  • Input Rating4 ohm
  • Woofer Diameter8"
  • ConfigurationDual Woofer (MTM)
  • ColorWhite
  • BrandBehringer
  • ModelCL208-WH
  • Part Number247-062
  • UPC736211585844
  • Weight32.41 lbs.
View similar products to the Behringer EUROCOM CL208-WH Compact 2-Way Dual 8" 200W 4 Ohm Loudspeaker - White
