Behringer EUROCOM CL106 Ultra-Compact 2-Way 6" 100W 8 Ohm Loudspeaker - Black
Brand:|Model: CL106|Part # 247-084
Featuring clean lines and a unique fabric-finished wrap-around grill, the CL106 is at home in even the most elegant settings: theaters and auditoria, houses of worship, themed and sporting venues, and more. With great response and sensitivity, it is designed to excel in small to medium venues.
List Price$169.99
Regular Price$139.99
You Save32%
Sale Price
Part # 247-084
  • 6" woofer provides tight, punchy bass
  • Constant directivity 90° x 70° rotatable waveguide with 1" high-frequency transducer for crisp, clear highs
  • Professional speaker connector (compatible with Neutrik Speakon® connectors) and 4-position terminal strip
  • 8 ohm impedance for simple integration
  • Powder coated steel grill wrapped with acoustically transparent fabric and foam, matching cabinet color
Thanks to their precision-engineered rotatable waveguides and computer-modeled transducers, CL Series loudspeakers deliver superior sonic performance. The CL106 features a 6" low frequency driver and a 1" high frequency compression driver, two available dispersion patterns, and is designed to blend into virtually any environment. The refined aesthetic design compliments even the most sophisticated interior spaces, and the compact form factor lends itself perfectly to A/V playback and delay fill in larger venues.
CL Series loudspeakers are constructed of durable laminated birch plywood and finished in either black or white. All models have metric threaded inserts for safe suspension using a variety of optional brackets and forged eyebolts. Designed for arrayed applications, all models (except subwoofers) are trapezoidal in shape and may be deployed in both vertical and horizontal orientations.
Superior Sonic Performance
The CL106 delivers exceptional sound quality, wide frequency bandwidth and dynamic range, featuring a 6" low frequency driver rated at 150 watts and a 1" high frequency compression driver rated at 20 watts RMS fitted to the high frequency waveguide.
Focused Projection
The 90° x 70° high frequency horn can be rotated in the field, allowing you to tailor your sound to fit virtually any venue or loudspeaker placement situation.
Meticulous Construction
The entire CL Series boasts internally braced, acoustically inert trapezoidal laminated birch plywood enclosures with 15° trapezoidal angles, designed for arrayed applications.
Elegant Style
Created in a subdued, non-descript, visually appealing style with a powder coated perforated wrap-around steel grill and acoustically transparent foam attached to match cabinet color, CL Series loudspeakers are available in black or white.
Diverse Rigging Options
The CL106 has fourteen (14) M10 threaded rigging points and four (4) M6 threaded inserts to accommodate an OmniMount™ 30-style bolt pattern.
The CL106 two-way compact trapezoidal loudspeaker system from Behringer is a powerful and versatile sound reinforcement loudspeaker designed for a variety of professional fixed installation applications in such venues as houses of worship, auditoriums, clubs, sports venues, and theaters. Every aspect of the CL106 has been thought through to maximize value and convenience for both the installer and the end user. The result is an attractive, durable, installation-ready loudspeaker system that will deliver top-notch sound day-after-day for years to come.
Specifications:  • Frequency range: 62 - 20,000 Hz (-10 dB); 69 - 15,000 Hz (±3 dB) • Nominal impedance: 8 ohms • Directivity factor (Q): 7.5 • Directivity index (DI): 8.8 dB • Sensitivity (1W/1m half space): 90 dB • Crossover frequency: 2500 Hz • Power handling (RMS, IEC passive): 100 watts • Maximum SPL: 110 dB (continuous); 116 dB (peak) • Dimensions: 17.7" H x 10.2" W x 11.3" D (450 x 260 x 286 mm) • Weight: 20.7lbs. (9.4 kg).
  • Input Rating8 ohm
  • Woofer Diameter6"
  • Configuration2-way
  • ColorBlack
  • BrandBehringer
  • ModelCL106
  • Part Number247-084
  • UPC736211584540
  • Weight28.65 lbs.
View similar products to the Behringer EUROCOM CL106 Ultra-Compact 2-Way 6" 100W 8 Ohm Loudspeaker - Black
