Behringer EPQ304 Europower 300W Lightweight 4-Ch Power Amp
Brand:|Model: EPQ304|Part # 248-6564
The EPQ304 300 watt amplifier packs 4 channels: 75 watts into 4 ohms, 50 watts into 8 ohms into a lightweight package weighing in at only 8.8 lbs.
List Price$344.99
You Save33%
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
*Domestic US orders only
Part # 248-6564
What makes Behringer's EPQ304 Europower amplifiers unique is its Accelerated Transient Response technology. By carefully selecting transistors with extremely high slew rates and optimizing other proprietary parts of our circuitry, our amps are able to react instantly to even the most demanding electronic bass impulses. If the woofers in your PA system can keep up, your audience will hear a tighter, crisper, more natural sound.
This lightweight amplifier features rail tracking for effectively modulating the power supply rails with only the peaks of the input signal, instead of operating relatively continuously like most power amps. This technology has revolutionized pro audio amp designs with its outstanding performance and efficiency. When combined with switching-mode power supplies that do away with heavy toroid transformers, our new designs provide more dynamic punch and, because they are so much more efficient, run cooler and don’t require huge, heavy heat sinks.
Behringer didn't invent this technology, but the R&D Department has been working for years to perfect this version, creating lightweight amps that run cool and also achieve our goal of Accelerated Transient Response.
Everything You Need
The simple front panel controls of these amps give you all of your sound’s vital signs at a glance. After pressing the Power Button, the POWER LED will light when the amp is ready for action. Both channels have independent gain dials as well as clip LEDs that indicate when the signal is distorted and you need to reduce the gain. There are also SIGNAL LEDs that light up when a signal is present at the input. The back panel of the EPQ304 accepts balanced XLR. The EPQ304 has an MONO On/Off switch for Inputs 1 AND 2, and another MONO On/Off switch for Inputs 3 and 4.
Behringer's new EPQ power amps are built for the working musician. They are exceptionally light, they pack massive power and they are built to last through all the rigors of the road. Plus its light price tag will leave you with enough cash left over to acquire more stuff to amplify! Check out the EPQ series and find out why Behringer power amps are among the most popular on Earth.
Specifications: • Output power, stereo (all channels driven): 65 watts RMS x 4 (4 ohm / 1 kHz @ 1% THD), 40 watts RMS x 4 (8 ohm / 1 kHz @ 1% THD), 75 watts peak x 4 (4 ohm / 1 kHz), 50 watts peak x 4 (8 ohm / 1 kHz)  • Output power, bridged mono (2 pairs channels bridged): 130 watts RMS x 2 (8 ohm / 1 kHz @1 % THD), 150 watts peak x 2 (8 ohm bridge mode) • Dimensions: 1.9" H x 19" W x 10.4" D (49 x 482 x 265 mm) • Weight: 8.8 lbs (4 kg).
  • Power Output (RMS Per Channel @ 8 ohms)40 Watts
  • Output Channels4
  • Weight Range< 10 lbs.
  • BrandBehringer
  • ModelEPQ304
  • Part Number248-6564
  • UPC705105165882
    (2 Reviews)
  • Weight12.55 lbs.
View similar products to the Behringer EPQ304 Europower 300W Lightweight 4-Ch Power Amp
