Behringer EPQ2000 Europower 2000W Lightweight 2-Ch Power Amp
Brand:|Model: EPQ2000|Part # 248-6562
EPQ2000 Europower 2,000 watt amplifier is exceptionally light, packs massive power and is built to last through all the rigors of the road.
  • 2 x 1,000 watts into 4 ohms; 2 x 600 watts into 8 ohms
  • ATR (Accelerated Transient Response) technology for ultimate punch and clarity
  • Ultra-light, ultra-low noise and ultra-efficient switch-mode power supply for noise-free audio
  • Switchable limiters offer maximum output level with reliable overload protection
  • Detented gain controls for precise setting and matching of sensitivity
  • Precise Power, Signal and Limit LEDs to monitor performance
  • XLR, 1/4" TRS and RCA input connectors for compatibility with any source
The EPQ Series power amplifiers pack the power of Accelerated Transient Response (ATR) technology into an exceptionally lightweight package. Ample power and high-tech efficiency combine to give you a feather-light supercharged workhorse that will keep your rig kicking for years to come. Instead of operating relatively continuously like most power amps, the EPQ power amps feature rail tracking for effectively modulating the power supply rails with only the peaks of the input signal. This technology has revolutionized pro audio amp designs with its outstanding performance and efficiency. When combined with switching-mode power supplies that do away with heavy toroid transformers, our new designs provide more dynamic punch and, because they are so much more efficient, run cooler and don't require huge, heavy heat sinks.
Everything You Need
The simple front panel controls of these amps give you all of your sound's vital signs at a glance. After pressing the Power Button, the POWER LED will light when the amp is ready for action. Both channels have independent gain dials as well as clip LEDs that indicate when the signal is distorted and you need to reduce the gain. There are also SIGNAL LEDs that light up when a signal is present at the input.
On the back panels of the EPQ2000 and EPQ1200, the INPUTs accept balanced XLR, 1/4" TRS, and unbalanced 1/4" TS and RCA connections. Take your pick of professional locking speaker outputs or touch-proof binding posts to securely connect speakers. The same panel contains the switches that allow you to put these amps to work in either mono, stereo (two channel mode) or mono bridge mode. A built-in CROSSOVER switch allow you to send low frequency content to subwoofers and other sound reinforcement speakers (CH1 < 100 Hz / CH2 > 100 Hz or FULL RANGE). Flick the LIMITER ON/OFF switch to activate the built-in overload protection, or turn it off if you're feeling lucky.
The back panels of the EPQ304, EPQ450 and EPQ900 accept balanced XLR. The EPQ450 and EPQ900 have MONO On/Off and BRIDGE On/Off switches. The EPQ304 has an MONO On/Off switch for Inputs 1 AND 2, and another MONO On/Off switch for Inputs 3 and 4.
Value
Behringer's new EPQ power amps are built for the working musician. They are exceptionally light, they pack massive power and they are built to last through all the rigors of the road. Plus its light price tag will leave you with enough cash left over to acquire more stuff to amplify! Check out the EPQ series and find out why Behringer power amps are among the most popular on Earth.
Specifications: • Output power: 500 watts @ 8 ohms per channel/700 watts @ 4 ohms per channel RMS; 600 watts @ 8 ohms per channel/1,000 watts @ 4 ohms per channel peak • Input impedance: 10 k ohms unbalanced, 20 k ohms balanced • Frequency response: 20 Hz - 20 kHz, 0/-1 dB • S/N Ratio: >100 dBA • Dimensions: 3.7" H x 19.0" W x 10.6" D (94 x 483 x 269 mm) • Weight: 15.4 lbs. (7.0 kg).
  • Power Output (RMS Per Channel @ 8 ohms)500 Watts
  • Output Channels2
  • Weight Range10 to 19 lbs.
  • BrandBehringer
  • ModelEPQ2000
  • Part Number248-6562
  • UPC713757155113
    (5 Reviews)
  • Weight15.43 lbs.
View similar products to the Behringer EPQ2000 Europower 2000W Lightweight 2-Ch Power Amp
