Behringer EPQ1200 Europower 1200W Lightweight 2-Ch Power Amp
Brand:|Model: EPQ1200|Part # 248-6560
The EPQ1200 Europower 1,200 watt amplifier is exceptionally light and packs massive power, built to last through all the rigors of the road.
  • 2 x 600 watts into 4 ohms; 2 x 320 watts into 8 ohms
  • ATR (Accelerated Transient Response) technology for ultimate punch and clarity
  • Ultra-light, ultra-low noise and ultra-efficient switch-mode power supply for noise-free audio
  • Switchable limiters offer maximum output level with reliable overload protection
  • Detented gain controls for precise setting and matching of sensitivity
  • Precise Power, Signal and Limit LEDs to monitor performance
  • XLR, 1/4" TRS and RCA input connectors for compatibility with any source
The EPQ Series power amplifiers pack the power of Accelerated Transient Response (ATR) technology into an exceptionally lightweight package. Ample power and high-tech efficiency combine to give you a feather-light supercharged workhorse that will keep your rig kicking for years to come. Instead of operating relatively continuously like most power amps, the EPQ power amp features rail tracking for effectively modulating the power supply rails with only the peaks of the input signal. This technology has revolutionized pro audio amp designs with its outstanding performance and efficiency. When combined with switching-mode power supplies that do away with heavy toroid transformers, this new design provides more dynamic punch and, because it's so much more efficient, runs cooler and doesn't require huge, heavy heat sinks.
Accelerated Transient Response Delivers the Knockout Punch
It takes huge pulses of energy (current and voltage) to propel a woofer cone out fast enough to match a bass beat. That's called Transient Response and it’s the holy grail of amp designers. By carefully selecting transistors with extremely high slew rates and optimizing other proprietary parts of our circuitry, our amps are able to react instantly to even the most demanding electronic bass impulses. If the woofers in your PA system can keep up, your audience will hear a tighter, crisper, more natural sound.
Everything You Need
The simple front panel controls of these amps give you all of your sound’s vital signs at a glance. After pressing the Power Button, the POWER LED will light when the amp is ready for action. Both channels have independent gain dials as well as clip LEDs that indicate when the signal is distorted and you need to reduce the gain. There are also SIGNAL LEDs that light up when a signal is present at the input.
On the back panels of the EPQ2000 and EPQ1200, the INPUTs accept balanced XLR, 1/4" TRS, and unbalanced 1/4" TS and RCA connections. Take your pick of professional locking speaker outputs or touch-proof binding posts to securely connect speakers. The same panel contains the switches that allow you to put these amps to work in either mono, stereo (two channel mode) or mono bridge mode. A built-in CROSSOVER switch allow you to send low frequency content to subwoofers and other sound reinforcement speakers (CH1 < 100 Hz / CH2 > 100 Hz or FULL RANGE). Flick the LIMITER ON/OFF switch to activate the built-in overload protection, or turn it off if you're feeling lucky.
Value
Behringer'
s new EPQ power amps are built for the working musician. They are exceptionally light, they pack massive power and they are built to last through all the rigors of the road. Plus its light price tag will leave you with enough cash left over to acquire more stuff to amplify!
Specifications: • Output power: 250 watts @ 8 ohms per channel/425 watts @ 4 ohms per channel RMS; 320 watts @ 8 ohms per channel/600 watts @ 4 ohms per channel peak • Input impedance: 10 k ohms unbalanced, 20 k ohms balanced • Frequency response: 20 Hz - 20 kHz, 0/-1 dB • S/N Ratio: >100 dBA • Dimensions: 3.7" H x 19.0" W x 10.6" D (94 x 483 x 269 mm) • Weight: 14.8 lbs. (6.7 kg).
  • Power Output (RMS Per Channel @ 8 ohms)250 Watts
  • Output Channels2
  • Weight Range10 to 19 lbs.
  • BrandBehringer
  • ModelEPQ1200
  • Part Number248-6560
  • UPC4033653070102
    (2 Reviews)
  • Weight14.77 lbs.
View similar products to the Behringer EPQ1200 Europower 1200W Lightweight 2-Ch Power Amp
