Behringer EPA300 300W 6-Channel Portable PA System
Brand:|Model: EPA300|Part # 248-6556
With its twin 150 watt amplifiers and custom-designed, 2-way loudspeakers, the EPA300 by Behringer can fill a small- to medium-sized room or project your voice for an incredible distance outdoors.
  • Ultra-compact 300 watt, 6-channel portable PA system
  • Enormous power, incredible sonic performance, and super-light weight
  • Extremely powerful 8" woofers and 1.35" aluminum-diaphragm compression drivers
  • Studio-grade 24-bit stereo FX processor with 100 awesome presets including reverb, chorus, flanger
  • FBQ Feedback Detection system instantly reveals critical frequencies for easy feedback removal
  • 6-channel mixer section features 2 mono and 2 stereo channels plus separate CD inputs
  • 2 high-quality mic preamps with switchable +48 V phantom power for condenser microphones
Looking for a supremely portable PA system? The new EPA300 from Behringer sets up in less than five minutes and delivers articulate, high fidelity performance. All the accessories you'll need are included in a convenient, easy to carry and set up package—and the good news is you don't have to be a sound engineer to run it!
Superb Sound Quality
Since Behringer already makes some of the best-sounding audio mixers, amplifiers and loudspeakers on the planet, it should come as no surprise that the EPA300 provides far superior sound quality than other products in this class. The two satellite speakers feature custom designed 8" woofers and 1.35" aluminum diaphragm compression drivers for incredible fidelity and clarity you might not expect from a loudspeaker system this small!
Control Freak..
Channels 1 – 2 feature high-quality Invisible Mic Preamps (IMP), which have been praised for their transparency and headroom. A Level control is provided with a Clip LED, so you can dial in the perfect signal level. We've also provided a Pad switch for those occasions when you have to contend with "hotter" than normal input levels.
Phantom Power is available, so you can use studio-grade condenser mics. Overall system response is handled by a 5-band stereo graphic EQ, and our proprietary FBQ Feedback Detection System helps you track and eliminate those annoying mic squeals.
Additionally, each input channel has a two-band EQ (Bass and Treble), Balance (allowing you to place the signal wherever you want within the stereo image) and an Effects level control. It is important to note that while some of Behringer's competitors only provide a reverb switch, the EPA300 features an FX level control per channel with 100 state-of-theart 24-bit digital FX to choose from. FX can be turned off/on via any standard footswitch (not included).
Speaking of FX...
If you’re making a speech, chances are you won't need it, but if you're playing a musical instrument and/or singing, you might want to add some effects. So, included is a 24-bit stereo FX processor with 100 great-sounding presets including reverb, chorus, flanger, delay, pitch shifter and various multi-effects to sweeten your performance. And if you want to sing along with pre-recorded tapes or CDs, the EPA300’s Voice Canceller function can remove virtually all the vocals from tracks played back through channels 5/6 with the simple flick of a switch.
It's All About Connections
The EPA300 comes ready for your input, literally. Channels 1 - 2 accept balanced XLR mics, as well as balanced and unbalanced 1/4" line-level sources, such as electronic keyboards and the like. Stereo channels 3/4 and 5/6 accommodate RCA and 1/4" unbalanced inputs, such as drum machines, keyboard sound modules, etc. All in all, there are enough mic and line-level inputs to handle a small band.
A Bonus Channel?
Want to play some of your favorite tunes at the company party? Just plug a CD/MP3 player into the Stereo Aux Inputs and crank it up! You don’t even have to give up a channel, just control the volume from the player. It's like getting eight channels for the price of six!
Everything You Need
The EPA300 is a complete system. Just set up the main unit on a tabletop, deploy the speakers and connect them with the included cables. Connect the high-quality dynamic microphone and hit the power switch—voilá, instant PA system! There is even an onboard storage compartment for the included microphone, accessories and cabling.
Whether you're making announcements and playing background music at the company picnic or rockin' out at the neighborhood coffee house, we think you will agree the EPA300 provides extreme value as a complete, portable PA solution. Compare it to the competition and you'll own Behringer.
Specifications: • Output power (@ 8 ohms): 130 watts per channel RMS, 150 watts per channel peak • Frequency response: 50 Hz to 25 kHz • S/N Ratio: 90 dB, A-weighted • Dimensions: 26.5" H x 20.5" W x 12.0" D (672 x 520 x 304 mm) • Weight: 45.3 lbs. (20.6 kg).
  • BrandBehringer
  • ModelEPA300
  • Part Number248-6556
  • UPC4033653061469
  • Product CategoryPortable PA Sound Systems
    (1 Reviews)
  • Weight56.8 lbs.
View similar products to the Behringer EPA300 300W 6-Channel Portable PA System
in the Portable PA Sound Systems product category.
