Behringer DX2000USB Professional 7 Channel DJ Mixer
Brand:|Model: DX2000USB|Part # 248-6652
The DX2000USB mixer has 2 mono microphone channels and five stereo music channels plus a USB input/output, the perfect multi-functional mixer designed for many applications.
List Price$449.99
You Save33%
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
*Domestic US orders only
Part # 248-6652
  • Professional, 7-channel, ultra-low noise DJ mixer with state-of-the-art phono preamps
  • 45 mm infinium "contact-free" optical crossfader with adjustable friction for years of use
  • 5 dual stereo inputs plus 2 mono mic/line channels with ULN mic preamps, Phantom Power, Gain control and Clip LED
  • Built-in USB interface for recording and playback of any digital music file. Works with your PC or Mac computer—no setup or drivers required
  • Free download of Tracktion music production software
  • Ultra-musical 3-band kill EQ (-32 dB) with EQ on/off switch on all stereo channels
If you're a DJ in need of accommodating more than just a mic and a couple of turntables then the DX2000USB is just the right mixer. You can accommodate a multimedia presentation, a variety of audio platforms (vinyl, CDs, mp3) and multiple mics—all at the same event! The DX2000USB is an invaluable tool for the DJ-of-all-trades.
If it can be clicked, spun or spoken, the new DX2000USB can mix it! You get 5 dual stereo inputs plus 2 mono mic/line channels with ultra low-noise mic preamps, Phantom Power, Gain control and Clip LED. The DX2000USB also has enough built-in phono preamps to handle up to three turntables. Finally, the built-in USB/audio interface gives you the power to add your computer's digital music library to the mix.
The DX2000USB is packed with cutting-edge versatility, but we didn't lose sight of the basic features that make a DJ mixer a lasting part of your rig. This new breed of DJ mixer features super-smooth ULTRAGLIDE faders with up to 500,000 life cycles, and an infinium optical VCA-controlled crossfader for utmost reliability and smooth audio performance.
The DX2000USB comes armed with a 3-band kill EQ and Gain control per channel. Mono channels feature an additional Low Cut switch and an FX switch that routes the channel to the FX SEND and RETURN loop, so you can add a touch of outboard effects. These channels, which accept microphones and 1/4" line sources, also feature a Talkover button, a Channel On button and PFL switch for headphone monitoring. Stereo channels have an EQ on/off switch, as well as a Crossfader button that sends the channel to the main stereo mix or the crossfader. An Assign button selects whether the channel appears on the X or Y side of the Crossfader.
For the DJ in need of mammoth bass, the DX2000USB features an XLR subwoofer output (perfect for connecting to an active subwoofer) with adjustable Crossover Frequency dial and Level control. Directly above, the DX2000USB provides a 1/4" main mono ouput for synching your music's strongest pulses with a lighting system. The Main Output section offers 1/4" and XLR stereo outputs, as well as 1/4" inputs for connection to outboard EQ units. This section also features RCA outputs for recording your set. The Monitor/Zone Output section gives you stereo 1/4" and XLR monitor outputs, as well as 1/4" stereo zone outputs.
When you add the DX2000USB to your rig, you connect to unrivaled versatility and performance at a price that will leave you with cash to spare. Its superior build quality and rugged components mean this mixer will serve you well for years to come.
Mono Input Channels: • Mic input: Electronically balanced, discrete input configuration • Mic input gain: +10 to +60 dB • Mic input frequency response: 10 Hz to 80 kHz, ±3 dB • Mic input THD: 0.08% typ. @ -30 dBu, 1 kHz • Line input gain: -10 to +40 dB • Line input frequency response: 10 Hz to 80 kHz, ±3 dB • Mic input THD: 0.08% typ. @ -10 dBu, 1 kHz • S/N ratio: 85 dB, unweighted.
Stereo Input Channels: • Phono/Line/CD input: Unbalanced input • Gain: Line/CD +17/-20 dB; Phone +17/-20 dB • Frequency response: Line/CD 10 Hz to 130 kHz, ±3 dB; Phone 20 Hz to 20 kHz, RIAA • THD: Line/CD 0.05% typ @ 0 dBu, 1 kHz; Phone 0.1% typ @ -40 dB, 1 kHz • S/N ratio: Line/CD -82 dB, unweighted; Phone -78 dB, unweighted.
Overall System: • Power consumption: 40 watts • Mains connector: Standard IEC receptacle • Dimensions: 2-3/8" / 6" x 17-1/4" x 14" (61 mm / 152.4 x 440 x 355.5 mm) • Weight: 14.3 lbs.
  • Special FeaturesRack Mountable,USB Connectivity
  • Stereo Line Input Channels7
  • Mic Inputs2
  • BrandBehringer
  • ModelDX2000USB
  • Part Number248-6652
  • UPC736211582744
  • Product CategoryDJ / Club Mixers
  • Weight18.4 lbs.
View similar products to the Behringer DX2000USB Professional 7 Channel DJ Mixer
in the DJ / Club Mixers product category.
