Behringer DR600 Digital Stereo Reverb Effects Pedal
Brand:|Model: DR600|Part # 248-6188
Thanks to the six renowned modes and extensive parameter control on the DR600 by Behringer, you will have maximum creativity and plenty of cools sounds at your disposal for every situation.
List Price$59.99
You Save33%
$39.99
Part # 248-6188
  • Ultimate digital reverb effects pedal comparable to state-of-the-art studio processors
  • 24-bit high-resolution stereo reverbs including Spring, Plate, Hall, Room, Gate, and Modulate
  • Dedicated Level, Tone, and Time controls for awesome sound shaping
  • Status LED for effect on/off and battery check
  • Runs on 9V battery or the Behringer PSU-SB DC power supply (not included)
  • First-class electronic On/Off switch for noise-free operation
  • High-quality components and exceptionally rugged construction ensure long life
You wouldn’t think of using anything less than best reverb you could get in the studio. So why skimp on the 'verb at your live gig? Now you can add studio-grade reverb to any amp with the mind-blowing DIGITAL REVERB DR600.
Six Pack
This 24-bit, high-resolution collection packs six (6) of the most desired reverb types—SPRING, PLATE, HALL, ROOM, GATE and MODULATE, into the ultimate "to-go" package. With its dual output jacks, you will dazzle your audience with true stereo reverb.
Ease of Use
Just select the reverb type with the MODE control, and then dial in the LEVEL, TONE and TIME. It just doesn’t get any easier than this. The blue LED tells you when the DR600 is activated, and the top-quality on/off switch maintains incredible signal integrity when in bypass mode. You can power the DR600 with a 9V battery or our PSU-SB DC power supply (not included).
Value
The DIGITAL REVERB DR600 brings six of the most-wanted reverbs to a stomp box right at your feet, at an unbelievably low price. Now studio-grade reverb is just a toe-tap away—with the Behringer DR600.
Specifications: • Input A/B connector: 1/4" TS • Input A/B impedance: 500k ohms • Input A impedance mono: 250k ohms • Output A/B connector: 1/4" TS • Output A/B impedance: 1k ohm • Power supply: 9 VDC, 100 mA, regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/4" H x 2-3/4" W x 4-4/5" D • Weight: Approx: 0.73 lbs.
  • BrandBehringer
  • ModelDR600
  • Part Number248-6188
  • UPC689076811187
  • Product CategoryGuitar & Bass Effects Pedals
    (2 Reviews)
  • Weight0.85 lbs.
View similar products to the Behringer DR600 Digital Stereo Reverb Effects Pedal
in the Guitar & Bass Effects Pedals product category.
