Behringer DM100 Distortion Modeling Effects Pedal
Brand:|Model: DM100|Part # 248-6186
Get three distortion pedals in one—sound modeled after the most legendary pedals. Crank up some hard-edged distortion without sacrificing the subtleties of your playing.
List Price$37.99
You Save34%
$24.99
Part # 248-6186
  • Get three distortion pedals in one—sound modeled after the most legendary pedals
  • Dedicated Distortion, Tone, and Level controls for awesome sound shaping
  • Status LED for effect on/off and battery check
  • Runs on 9V battery or the Behringer PSU-SB DC power supply (not included)
  • First-class electronic On/Off switch for noise-free operation
  • High-quality components and exceptionally rugged construction ensure long life
You could spend loads of money and time tracking down the vintage dirt boxes responsible for rock's defining moments—and pay a lot for just one of them. But why settle for just one? Now you can have three of them in one incredibly affordable analog pedal—the BEHRINGER Distortion Modeler DM100!
Multiple Personalities
With the DM100, you get three immaculate fuzz flavors—D+, DS1 and RAT. Just select one of these three classic mode settings, then dial in precisely the sound you want using the dedicated DISTORTION, TONE and LEVEL dials. You won't believe your ears as rock n' roll's most coveted tones explode from this amazing and ultra-affordable stomp box.
Ease of Use
The bright, blue LED tells you when it’s activated, and the durable on/off switch maintains crystal-clear signal integrity in bypass mode. You can power the DM100 with a 9V battery or a Behringer DC power supply (not included).
Value
With the DM100 in your effects chain, you'll skip run-of-the-mill tone and go straight to top-shelf. Three landmark rock n' roll tones in one incredible stomp box—the Distortion Modeler DM100. Designed for use with guitars, bass, and keyboards.
Specifications: • Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector: 1/4" TS • Output impedance: 1k ohm • Power supply: 9V, 100mA DC regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelDM100
  • Part Number248-6186
  • UPC4033653051118
  • Product CategoryGuitar & Bass Effects Pedals
    (2 Reviews)
  • Weight0.8 lbs.
View similar products to the Behringer DM100 Distortion Modeling Effects Pedal
in the Guitar & Bass Effects Pedals product category.
Behringer DM100 Distortion Modeling Effects Pedal is rated 3.0 out of 5 by 2.
Rated 1 out of 5 by from VERY POOR PEDALFirst off, DON'T stomp this box, it's plastic. The "tone" wasn't the weak point, it was the MUSH as you attack the note. It didn't matter where the "level" was, it was mush at the attack of any note or chord. The real bad problem was the thing is SUPER microphonic! You could NEVER use this thing at any volume. Tap the plastic case with your finger and it rings through the amp as loud as can be. Very poor quality product at any price.
Date published: 2012-03-11
Rated 5 out of 5 by from distortions that actually sound different .The sounds are all very usable and respond well in their own way. I was blown away by the sound options for the dough spent.
Date published: 2010-09-27
  • 2016-02-13T06:56CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_248-6186, PRD, sort_mostRecent
