Behringer DI600P High-Performace Passive DI Box
Brand:|Model: DI600P|Part # 248-6182
With the DI600P as your go-between, impedance-matching problems become a thing of the past, and long cable runs will not sacrifice all of your precious tone.
- Order Soon - Only 3 Left In Stock
List Price$44.99
You Save33%
$29.99
Part # 248-6182
  • Converts any unbalanced line-level signal to balanced mic-level output
  • Allows the use of long cables without losing high frequencies
  • Switchable input for connecting instruments or amplifiers with outputs up to 3,000 Watts
  • Filter switch reduces annoying hiss and buzz
  • Ground lift switch eliminates typical ground loop problems such as hum
  • High-performance transformer for ultimate signal integrity
  • Ultra-compact, all-metal, and road-suitable housing
The ULTRA-DI DI600P is a passive DI (Direct Injection) box for connecting a guitar, bass or keyboard directly to your mixer. With its parallel 1/4" IN and OUT jacks, the DI600P allows you to plug in your instrument and send the same signal to your onstage amplifier, while the XLR OUTPUT sends a balanced signal to your mixer. A ground lift switch eliminates hum associated with ground loops and our high-performance transformer provides the ultimate in signal integrity.
Special Feature
Just flip the INST/AMP switch and the DI600P can easily accommodate either the low-level signal of a high-impedance mic or guitar (INST mode), or the speaker output of a guitar amplifier (AMP mode). Even if your amp cranks out as much as 3,000 watts, you get a perfect signal every time!
Great Sound, Exceptional Value
The ULTRA-DI DI600P is also ultra-compact, and we house it in a tough, road-ready metal case. This means the DI box will give you great sound gig after gig, session after session. And thanks to its low price, you can afford to outfit the entire band.
Specifications: • Input: 1/4" TS (unbalanced) • Output: Balanced XLR • Frequency response: 40 Hz (-3 dB) to 20 kHz • THD+N: 0.003% @ 1 kHz • Dimensions: 1.4" H x 5" W x 3.75" D • Weight: Approx. 0.66 lbs.
  • Active / PassivePassive
  • Rack MountableNo
  • BrandBehringer
  • ModelDI600P
  • Part Number248-6182
  • UPC689076807685
  • Product CategoryDirect Boxes
  • Weight0.8 lbs.
View similar products to the Behringer DI600P High-Performace Passive DI Box
in the Direct Boxes product category.
