Behringer DI400P High-Performance Passive DI Box
Brand:|Model: DI400P|Part # 248-6180
With its parallel 1/4" IN and OUT jacks, the DI400P by Behringer allows you to plug in your instrument and send the same signal to your onstage amplifier, while the XLR OUTPUT sends a balanced signal to your mixer.
List Price$29.99
You Save33%
Part # 248-6180
  • Converts any unbalanced line-level signal to balanced mic-level output
  • Allows the use of long cables without losing high frequencies
  • Ground lift switch eliminates typical ground loop problems such as hum
  • High-performance transformer for ultimate signal integrity
  • Ultra-compact, all-metal and road-suitable housing
  • High-quality components and exceptionally rugged construction ensure long life and durability
The ULTRA-DI DI400P is a passive DI (Direct Injection) box for connecting a guitar, bass or keyboard directly to your mixer. With the DI400P as your go-between, impedance-matching problems become a thing of the past, and long cable runs will not sacrifice all of your precious tone. A ground lift switch eliminates hum associated with ground loops and our high-performance transformer provides the ultimate in signal integrity.
Great Sound, Exceptional Value
The ULTRA-DI DI400P is also ultra-compact and we house it in a tough, road-ready metal case. This means the DI box will give you great sound gig after gig, session after session. And thanks to its low price, you can afford to outfit the entire band.
Specifications: • Frequency response: 40 Hz - 20 kHz (-3 dB) • THD+N: 0.007% @ 1 kHz, input level +4 dBu • Input: 1/4" TS (unbalanced) • Level change: -20 dB • Output: Balanced XLR • Impedance ratio: 110:1 • Dimensions: 1.4" H x 4.7" W x 2.6" D • Weight: Approx. 0.44 lbs.
  • Active / PassivePassive
  • Rack MountableNo
  • BrandBehringer
  • ModelDI400P
  • Part Number248-6180
  • UPC689076808385
  • Product CategoryDirect Boxes
    (2 Reviews)
  • Weight0.54 lbs.
View similar products to the Behringer DI400P High-Performance Passive DI Box
in the Direct Boxes product category.
