BONUS ITEM INCLUDED
248-6458_ALT_0
248-6458_ALT_1
248-6458_ALT_2
Behringer DDM4000 5-Ch Digital Pro DJ Mixer
Brand:|Model: DDM4000|Part # 248-6458
Behringer's DDM4000 is a state-of-the-art 32 bit digital mixer with 5 independent channels, MIDI functionality, and stunning dual FX.
List Price$524.99
You Save33%
$349.99
Behringer Baseball Cap
Qty: 1Part # 520-306
List Price:$19.99
Behringer HPM1000 Multi-Purpose Headphones
Qty: 1Part # 248-6248
List Price:$14.99
Part # 248-6458
  • 4 Phono/Line stereo channels allowing max. 8 signal sources to be connected simultaneously
  • 2 Microphone inputs with Gain, EQ, Talk function and FX
  • 2 freely assignable and BPM-synchronized, high-quality FX engines
  • Dual-mode crossfader with innovative frequency-selective crossfading
  • Dedicated Headphone section includes PFL Mix/Split and Bass/Snare boost functions
  • Recall your last mixer setting at the push of a button
  • Digital S/PDIF output for direct recording of your performance
The DDM4000 is a 32-bit digital DJ mixer, jam-packed with creative tools, yet its intuitive layout will let you feel at home in an instant. Editing, storing and recalling your settings is simply a breeze!
Hook up your turntables and CD/MP3 players to its 4 stereo channels, each with fully programmable EQ and Kill switches. Put ultimate versatility at your fingertips with fully programmable beat-sync'able multi-FX modules, a pair of high-precision BPM counters and a digital crossfader with custom curve adjustment. And the super-cool BPM-sync'd sampler with real-time pitch control, loop and reverse functions will make your crowd go wild.
Get this deejaytal monster DDM4000 and become the star of the night!
Mixer the Magnificent
The DDM4000 is Behringer's state-of-the-art 32-bit digital DJ mixer. It's hard to believe the amount of features crammed into this thing. Read on.
Choose Your Channel
The DDM4000 struts 5 independent channels. Channels 1-4 are crossfader-assignable stereo channels, suitable for both vinyl and CD decks, and have appropriate phono/line level toggle switches at the input. All channels feature 3-band digital EQs with up to 12 dB of boost and infinite cut option, or "kill." Any channel can be monitored directly via headphones thanks to the PFL switch above the fader.
A dedicated Mic channel is provided in mono, with 2 XLR mic inputs. The vocal channel features a special "talk" feature that attenuates the volume of the other 4 channels, ensuring you will be heard over the music. The Mic channel also has its own FX section that can be applied with a single button.
Cross My Heart
The core functionality of any DJ mixer lays in its crossfader. The DDM4000's crossfader can be assigned to any of channels 1-4, and sports a 3-band EQ kill button on either side. The curve sensitivity of the crossfader is adjustable, and in the unlikely event that you wear it out, the crossfader itself is replaceable.
Step Up Your Samplin'
The DDM4000’s BPM-synced sampler is a sought-after addition. The sampler allows you to record a segment of incoming audio and loop it continuously without dropping the beat. Once your track is looping from the sampler, you can swap discs and queue up new tracks and mix them back in. The transition is seamless!
Effects
The DDM4000 features a stunning dual FX section that includes our patented BPM counting technology. This allows the mixer to read/display the BPM of 2 different inputs and to apply BPM-synchronized effects, such as an echo synced to the beat of the music. Effects such as bitcrusher, reverb, delay, pitch shift, and more are available, and can be assigned independently to multiple channels.
The DDM4000 is ideal for a club owner who has multiple working DJs performing on a recurring basis. User preferences like fader curve, FX settings, EQ, kill frequencies, etc., can all be set to various user accounts and recalled instantly. This feature can eliminate setup time between DJs altogether!
Swimming Upstream
When you combine the DDM4000's digital operation with MIDI functionality, the door to creative applications opens REALLY wide. For example, the mixer can be used as a MIDI controller for your favorite DJ software—or whatever else you like! Channel faders, EQ knobs, and button presses can all be configured to send customized MIDI data. The possibilities here are quite endless.
All the Hits and More
The DDM4000 provides top-level functionality for the experienced DJ, at a cost that will have you smiling all the way to the bank.
  • Special FeaturesBuilt In Digital Effects
  • Stereo Line Input Channels4
  • Mic Inputs2
  • BrandBehringer
  • ModelDDM4000
  • Part Number248-6458
  • UPC689076151115
  • Product CategoryDJ / Club Mixers
    (1 Reviews)
  • Weight15.3 lbs.
View similar products to the Behringer DDM4000 5-Ch Digital Pro DJ Mixer
in the DJ / Club Mixers product category.
Behringer DDM4000 5-Ch Digital Pro DJ Mixer is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Best value in the DJ mixer market, hands downThis DJ mixer is by far the best mixer out there for the money. Definately the best mixer to come out from Behringer in a while, this thing is LOADED with features. Sound quality is excellent. Some features to note that many places fail to acknowledge: a dedicated subwoofer out with 2-way crossover (yes it will high-pass the mains for you if turn the sub mode on) with vaiable frequency adjustment, multiple user settings, built-in compressor/limiter (called the ultramizer) with adjustable parameters, an insane effects processor, very accurate bpm counter (integrates with the effects to provide proper effects timing), fully midi-mappable for software like Virtual DJ, Traktor, etc. The faders are optical and feel pretty good. I'm a scratch DJ and pretty much wore out the stock crossfader. I replaced it with an Innofader and the installation for the mixer is pretty easy and it works AWESOME with it. Built-in sampler is very good. The mic section is fantastic. The Mic section has it's own effects section, independent of the main one. It also has it's own compressor, parametric EQ (as does the regular main channels), and just sounds great. Full array of inputs and outputs. The unit is extremely lightweight, but don't know how due to how much "stuff" this mixer has. Midi mode allows you put only what you want in midi mode (ex., I am running ch 1 and 4 in midi and the 2 & 3 are regualar analog). I use the 1 and 4 for controlling Virtual DJ (knobs, buttons, and sliders) and the 2&3 and crossfader are analog for my sound fading/mixing. This mixer offers so much at such a low price it's hard to want to accept it at first. Most people are skeptical because of the name and also for how much this mixer can do at the low price. I am one of many beleivers that this unit is one of the best kept secrets in the DJ world. I bought mine new two years ago (not from PE) for even less. IT's hands down the best mixer you'll ever buy new, for the $$.
Date published: 2011-02-03
  • 2016-02-14T06:54CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_248-6458, PRD, sort_mostRecent
How is indian prize this mixer? Because i want buy this mixer emmediatly.
Asked by: roshan bhoir
Please contact our sales and customer service for available stock, price and shipping options. sales@parts-express.com or 800-338-0531 x2.
Date published: 2015-01-21
  • 2016-02-14T07:48CST
  • loc_en_US, sid_248-6458, PRD, sort_recentQuestionsFirst
