Behringer DD400 Digital Stereo Delay / Echo Effects Pedal
Brand:|Model: DD400|Part # 248-6174
The DD400 effects pedal offers subtle to radical stereo delay and echo with a resolution comparable to state-of-the-art studio processors.
List Price$59.99
You Save33%
$39.99
Part # 248-6174
  • 24-bit high-resolution stereo delay/echo with delay time up to 1.3 s
  • Dedicated Mode, Time, Feedback and Level controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9 V battery or the BEHRINGER PSU-SB DC power supply (not included)
  • First-class electronic On/Off switch for highest signal integrity in bypass mode
  • High-quality components and exceptionally rugged construction ensure long life
The Behringer DD400 has an obsession with the past—the last 1.3 seconds of it, to be exact.
What is delay?
Delay is a synthetic echo that, in adjustable increments, repeats the notes you play on guitar. Each repeated tone becomes quieter than the previous one, until the repeats are no longer heard. This results in a thick, robust sound that can take on everything from the quick "slap" echo of classic rockabilly to the long, dreamy echoes found in psychedelic rock.
Superior Sound
This box will sing the fading, ghostly praises of every note you squeeze from your axe. With seven modes of delay to choose from, there is a vast pallete of echoes to explore with the DD400. Take advantage of its full 1.3-second memory or scale it back for a more abrupt echo. Just twist the dedicated Mode, Time, Feedback and Level controls to create the delay of your dreams. There is also a HOLD mode that allows you to loop a brief riff, then play over it. The blue LED tells you when it's on, and the first-class on/off switch maintains incredible signal integrity in bypass mode. You can power the DD400 with a 9V battery or a DC power adapter.
Value
Giving your sound a transcendental twist has never sounded better, or been more affordable! When it's atmosphere your guitar craves, put the DD400 to work for you.
Specifications: • Input connector: 1/4" TS • Input impedance: 500k ohms • Output A/B connector: 1/4" TS • Output A/B impedance: 1k ohm • Power supply: 9VDC, 100mA DC regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelDD400
  • Part Number248-6174
  • UPC689076752879
  • Product CategoryGuitar & Bass Effects Pedals
    (4 Reviews)
  • Weight0.85 lbs.
View similar products to the Behringer DD400 Digital Stereo Delay / Echo Effects Pedal
in the Guitar & Bass Effects Pedals product category.
