Behringer DC9 Classic Dynamics Compressor Effects Pedal
Brand:|Model: DC9|Part # 248-6172
The DC9 classic dynamics compressor stomp box by Behringer gives your clean guitar a powerful, percussive sound, and even melts steel alloy with its endless sustain.
Comparable Items In Stock:
Part # 248-6172
  • Smoothes out volume peaks and provides endless sustain with ultra-stable dynamics
  • Blue status LED for effect on/off and battery check
  • True hard-wire bypass for ultimate signal integrity
  • Runs on 9V battery or the Behringer PSU-SB DC power supply (not included)
  • High-quality components and exceptionally rugged construction ensure long life
Compression gives strong presence and snappy attitude to your clean sound while making your leads absolutely scream. The DC9 gives you an incredible compressed sound in one tough, easy-to-use stomp box.
What's a Compressor?
Dynamics play an important role in music. They help to convey emotion, whether it's a sultry blues solo or the unrelenting gallop of unfettered metal. But uncontrolled dynamics can take all your best intentions and turn them into so much, well…mush. That's where compression comes in, softening loud sounds and boosting low signal levels to keep everything more uniform. So, a compressor's main job is to make every note the same volume.
Balancing Act
Ever notice how some strings on your guitar or bass sound louder than others? This is partly due to physics. Strings with lower mass just don't put out as much volume as the heavier ones. When used properly, a compressor makes all of the strings the same volume. Compressors are also great for slap-style bass players, making thumb slaps, string pulls and muted notes all the same volume, for an extremely percussive effect.
Easy to Use
Just twist the dedicated Output dial to determine how much volume you want it to kick out, then adjust the Sensitivity dial to determine the level where everything from delicate strumming to aggressive picking will be heard with equal presence. Whether you're ready to tear up the countryside with some down-home chicken-pickin' or melt faces with a searing metal solo, the DC9 will change your idea of ideal tone. The blue status LED tells you when the DC9 is on, while the true hardware on/off switch maintains the highest quality signal integrity in bypass mode. You can power it with a 9V battery or a DC power supply (not included).
Value
When your music is too good to be ignored, play it through the Dynamics Compressor DC9. Your sound will be impossible to miss!
Specifications: • Input connector: 1/4" TS • Input impedance: 1M ohms • Output connector: 1/4" TS • Output impedance: 1k ohm • Power supply: 9VDC, 100mA DC regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/5" H x 4-2/5" W x 2-2/3" D (56 x 113 x 69 mm) • Weight: Approx. 0.53 lbs. (0.24 kg).
  • BrandBehringer
  • ModelDC9
  • Part Number248-6172
  • UPC4033653053075
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.73 lbs.
View similar products to the Behringer DC9 Classic Dynamics Compressor Effects Pedal
in the Guitar & Bass Effects Pedals product category.
