Behringer CS400 Compressor / Sustainer Effects Pedal
Brand:|Model: CS400|Part # 248-6170
The CS400 by Behringer is the ultimate effect pedal specifically designed to achieve super-smooth compression and endless sustain thanks to its high-performance features that allow you to compress loud and boast low signals without degrading the original sound.
List Price$37.99
You Save34%
$24.99
Part # 248-6170
  • Get super-smooth compression and endless sustain
  • Designed to compete head to head with leading products on the market
  • Compress loud and boost low signals without degrading the original sound
  • Dedicated Level, Tone, Attack and Sustain controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the BEHRINGER PSU-SB DC power supply (sold separately)
  • First-class electronic On/Off switch for highest signal integrity in bypass mode
If tone is the name of your game, the COMPRESSOR/SUSTAINER CS400 will add amazing impact to your tone and provide endless sustain.
What's a Compressor?
Dynamics play an important role in music. They help to convey emotion, whether it's a sultry blues solo or the unrelenting gallop of unfettered metal. But uncontrolled dynamics can take all your best intentions and turn them into so much, well…mush. That’s where compression comes in, softening loud sounds and boosting low signal levels to keep everything more uniform. So, a compressor’s main job is to make every note the same volume.
Balancing Act
Ever notice how some strings on your guitar or bass sound louder than others? This is partly due to physics. Strings with lower mass just don't put out as much volume as the heavier ones. When used properly, a compressor makes all of the strings the same volume. Compressors are also great for slap-style bass players, making thumb slaps, string pulls and muted notes all the same volume, for an extremely percussive effect.
Easy to Operate
You can dial in the right amount of compression using the dedicated ATTACK and SUSTAIN dials. The LEVEL control allows you to set the output to subtle, or engage a monster volume boost. TONE lets you add exactly the right level of highs. From clean, snappy country leads to rock solos that scream for eons, the CS400 is built to make your sound the center of attention. Its LED tells you when it's on, and the top-quality on/off switch maintains outstanding signal integrity in bypass mode. You can power this scene-stealer with either a 9V battery or our PSU-SB DC power supply (not included).
Value
The COMPRESSOR/SUSTAINER CS400 is an affordable way to add some serious finesse to your playing.
Specifications: • Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector: 1/4" TS • Output impedance: 1k ohm • Power supply: 9 VDC, 100 mA DC regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D • Weight: Approx. 0.73 lbs.
  • BrandBehringer
  • ModelCS400
  • Part Number248-6170
  • UPC736211842879
  • Product CategoryGuitar & Bass Effects Pedals
    (3 Reviews)
  • Weight0.8 lbs.
View similar products to the Behringer CS400 Compressor / Sustainer Effects Pedal
in the Guitar & Bass Effects Pedals product category.
