Behringer CMD PL-1 MIDI DJ Module with 4" Touch-Sensitive Platter
Brand:|Model: CMD PL-1 |Part # 248-6846
Part of the new CMD Command Series of modular DJ controllers, the CMD PL-1 is a great MIDI controller with a 4" touch-sensitive platter for your favorite DJ software, or it can be integrated into your CMD modular system. Mix and match CMD modules to get exactly the controls you need, just how you want them, with Behringer's quality and reliability.
List Price$149.99
You Save33%
$99.99
Part # 248-6846
  • Compatible with popular DJ software including Native Instruments Traktor, Serato Scratch Live, Ableton Live and any other MIDI-compatible programs
  • Image Line Deckadance LE DJ software voucher included
  • 4" high-resolution touch-sensitive platter and 14-bit pitch fader with LED feedback
  • Designed to lock together with other Behringer CMD controllers for full expandability
  • 3-year warranty
Behringer Command Series DJ Controllers finally give the DJ market what they've been waiting for: a truly modular system of MIDI controllers that can be put together to precisely suit your software needs and mixing style. Each module is packed with professional features, from high quality faders to extensive MIDI feedback, and all the features are organized into logical, intuitive groups. This gives you a clear idea of what each module is for and how it can be used, without needing to read a huge manual first. And all CMD controllers are class-compliant, meaning that no additional drivers are required; just connect and go.
CMD PL-1 Platter Control Module
Small enough to fit in a tight DJ booth, but big enough to deliver the performance you need, the PL-1 is a robust platter controller, no matter what DJ software you use.
With its 4" touch-sensitive wheel, the PL-1 knows when you’re touching it and where. Touch on the top, and the music stops just as if you were touching a record. Nudge the side of the platter and you’ll get momentary changes in playback speed. It performs exactly as you’ve come to expect from years of turntable and CD deck use. However, unlike most other deck controllers, this little dynamo comes with a silky-smooth, high-resolution fader for precise pitch adjustments. If you use sync in your software and the deck pitch changes, there’s a column of LEDs next to the pitch fader that lets you know what the pitch on the virtual deck has changed to, so you always know what’s going on without looking at your screen.
Only have room for one controller in your booth? Not a problem! The PL-1 supports deck switching for controlling up to four decks, so a single module is the perfect backup deck or add-on when using software that allows for more than two virtual decks.
But just one controller? That’s no fun! Remember the old saying, "go big or go home?" So why not pair up four PL-1 controllers with an MM-1 mixer module and enjoy the ultimate four deck experience? Four channels, four platters, no confusion. And still easily portable. Isn't it nice to have choices?
A Stand Alone Controller
The CMD Series modules work well as standalone controllers for a wide range of DJ and production software. Whether you’re a DJ, producer, recording engineer, or hobbyist, CMD controllers make getting a grip on your software easy and affordable. They’re big enough to be taken seriously, but small enough to fit easily into a backpack or messenger bag. And because they’re modular, there’s always room to grow if you decide you want or need even more control over your software.
Using Multiple Modules
This is where the real power of the CMD controllers becomes clear. As a Serato ScratchLive user, you might be particularly interested in the DV-1 MIDI module with dual effects controls. But what if you want to use Bridge to incorporate Ableton Live into your setup? Easy! Just add an LC-1 next to your DV-1 and you’re all set. Or what if you want to use a traditional DJ mixer, but still want MIDI control for Traktor’s decks and effects? No problem, use a PL-1 and DV-1 together. Want to use Ableton Live exclusively? Get an MM-1 and LC-1 and you have control over 4 channels in Live. The possibilities are endless! See "Related Products" to the right, and let your imagination run wild!
Specifications: • USB connector: 1 x USB 2.0 type B • Dimensions: 12.0" x 6.0" x 2.2" (305 x 152 x 57 mm) • Weight: 2.0 lbs. (0.9 kg).
  • Special FeaturesUSB Connectivity
  • BrandBehringer
  • ModelCMD PL-1
  • Part Number248-6846
  • UPC794504550818
  • Product CategoryDJ / Club Mixers
  • Weight4.3000 lbs.
View similar products to the Behringer CMD PL-1 MIDI DJ Module with 4" Touch-Sensitive Platter
in the DJ / Club Mixers product category.
