Behringer CL9 Classic Compressor / Limiter Effects Pedal
Brand:|Model: CL9|Part # 248-6164
Achieve super-smooth compression and extended sustain with the high-performance CL9 classic compressor by Behringer.
List Price$37.99
You Save34%
$24.99
Part # 248-6164
  • Smoothes out volume peaks and provides endless sustain with ultra-stable dynamics
  • Dedicated Sustain, Level and Attack time controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • First-class electronic On/Off switch for highest signal integrity in bypass mode
  • Runs on 9V battery or the Behringer PSU-SB DC power supply (not included)
  • High-quality components and exceptionally rugged construction ensure long life
Compress, impress and kick ass
Whether it's a million-dollar hook or a soul-wrenching solo, some licks are just begging for the compression power of the Behringer CL9. By pumping up quieter notes and bringing down the louder ones, this stomp box packages your sound into one smooth, consistent volume.
What is a Compressor?
Dynamics play an important role in music. They help to convey emotion, whether it's a sultry blues solo or the unrelenting gallop of unfettered metal. But uncontrolled dynamics can take all your best intentions and turn them into so much, well…mush. That''s where compression comes in, softening loud sounds and boosting low signal levels to keep everything more uniform. So, a compressor's main job is to make every note the same volume.
Balancing Act
Ever notice how some strings on your guitar or bass sound louder than others? This is partly due to physics. Strings with lower mass just don’t put out as much volume as the heavier ones. When used properly, a compressor makes all of the strings the same volume. Compressors are also great for slap-style bass players, making thumb slaps, string pulls and muted notes all the same volume, for an extremely percussive effect.
It's Easy!
Twist the Level to determine this pedal's overall output, adjust Attack to give the front end of every strum and pluck added definition, then dial in the amount of sustain desired. The blue LED tells you when it’s on, and the high-quality on/off switch maintains incredible signal integrity in bypass mode. You can power this sound compactor with either a 9V battery or a DC power supply (not included).
Specifications: • Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector: 1/4" TS • Output  impedance: 1k ohm • Power supply: 9VDC, 100mA DC regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelCL9
  • Part Number248-6164
  • UPC689076115612
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.85 lbs.
View similar products to the Behringer CL9 Classic Compressor / Limiter Effects Pedal
in the Guitar & Bass Effects Pedals product category.
