Behringer CD400 Ditigal 3-Dimensional Sound Effects Pedal
Brand:|Model: CD400|Part # 248-6638
Add texture to your guitar's sound with the 3-dimensional sound CD400 effect pedal by Behringer.
  • Add a breathtaking third dimension to your sound or instrument and experience the secret weapon of professional recording studios
  • Real Sound Modeling (RSM) combines state-of-the-art DSP technology with sophisticated algorithms to emulate real acoustic environments
  • Dedicated Depth, Rate, EQ and Level controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the Behringer PSU-SB DC power supply (not included)
  • First-class electronic On/Off switch for highest signal integrity in bypass mode
With a dedicated EQ control, the CD400 by Behringer gives you total control over your chorus' treble content. Still has all the standard features you need with depth, rate, and level dials. Soft and supple, or sharp as a razor's edge—your thumb and forefinger have never had it so good!
Inside this "little black box" there is yet another "little black box"—our state-of-the-art Real Sound Modeling (RSM) processor. Here we infuse your signal with a little "Top-Secret" technological magic, creating one of the most dense, melodic and detailed chorus effects you've never heard!
CD400's footswitch is electronic, so that it can stand up to years of hard use, while maintaining absolute signal integrity in bypass mode. The CD400 effects pedal can be used with our PSU-SB DC power supply or a simple 9V battery for mobile applications. A clear blue LED indicates power status and battery condition.
Specifications: • Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector A: 1/4" TS • Output impedance A: 1k ohm • Output connector B: 1/4" TS • Output impedance B: 1k ohm • Power supply: 9 VDC, 100 mA regulated (sold separately) • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 (sold separately) • Power consumption: 30 mA • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelCD400
  • Part Number248-6638
  • UPC4033653052740
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.88 lbs.
View similar products to the Behringer CD400 Ditigal 3-Dimensional Sound Effects Pedal
in the Guitar & Bass Effects Pedals product category.
