Behringer BXL3000 Ultrabass 1x15" 300W Bass Combo Amp
Brand:|Model: BXL3000|Part # 248-6138
The BXL3000 by Behringer is a 300 watt 2-channel bass workstation with original BUGERA 15" speaker, FBQ spectrum analyzer, compressor, and Ultrabass processor.
  • Powerful 300-Watt 2-channel Bass Workstation in wedge-shaped cabinet
  • Original BUGERA 15" special high-impact cone speaker
  • Clean channel with dedicated Gain control
  • Distortion channel with dedicated Gain, Shape and Level controls
  • Ultra-musical, active 7-band graphic EQ with FBQ Spectrum Analyzer
  • Revolutionary "See what you play" FBQ frequency indicator for instant sound shaping
  • Switchable Ultrabass subharmonics processor for unbelievable low-end power
When a stack is too high and a practice amp just doesn't cut it, then this truly affordable wedge-shaped Bass Workstation with a powerful 15" special high-impact cone speaker is exactly right! With 300 watts of output horsepower, your performance will never run out of breath. And it's fully loaded: one clean and one distortion channel with full control, a 7-band EQ with a revolutionary
See-What-You-Play FBQ frequency indicator that immediately shows you which bass frequency corresponds with which fader on your EQ to allow you instant sound shaping, a switchable Ultrabass subharmonics processor, and a compressor with adjustable threshold are just a few of the feature highlights. A musical limiter guarantees playing without distortion on the clean channel even at the highest volume levels, plus we've included a dual footswitch for channel select. Using external FX units is easy with the dedicated FX insert, and you can use the separate headphone output whenever you need to keep your music just to yourself.
Specifications: • Amplifier power output: 300 watts @ 4 ohms • Loudspeaker type: 15" • Impedance: 4 ohms • Power handling: 200 watts • Dimensions: 24" H x 18.4" W x 16.5" D • Weight: 60.5 lbs.
  • For use withBass Guitar
  • BrandBehringer
  • ModelBXL3000
  • Part Number248-6138
  • UPC689076751971
  • Product CategoryGuitar / Bass Combo Amplifiers
  • Weight67.02 lbs.
View similar products to the Behringer BXL3000 Ultrabass 1x15" 300W Bass Combo Amp
in the Guitar / Bass Combo Amplifiers product category.
