Behringer BUF300 Ultimate Bass Flanger Effects Pedal
Brand:|Model: BUF300|Part # 248-6120
The BUF300 effects pedal lets you lift off with swirling jet sounds, thick chorus, vibrato, and short delay effects without affecting the bass fundamentals, keeping the original bass punch and clarity.
  • Take off with flanging jet sounds, thick chorus, vibrato and short delay effects
  • Retains your original bass punch and clarity without affecting the bass fundamentals
  • Dedicated Resonance, Rate, Depth and Manual controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • First-class electronic On/Off switch for highest signal integrity in bypass mode
  • High quality components and exceptionally rugged construction ensure long life
Is your bass sounding a little too…normal? Inject it with a dose of the Ultra Bass Flanger BUF300 and watch as your once-tame low end melts into a bubbling tar pit.
Best of Both Worlds
The BUF300 allows you to add the swirling sound of flanging to your bass, without sacrificing bottom end and clarity. From mild to wild, the dedicated RESONANCE, RATE, DEPTH and MANUAL controls give you the flexibility to create your very own brand of low-end lunacy.
Superior Build Quality
Designed to withstand the rigors of the road, the BUF300’s build quality is second to none. A bright, blue status LED tells you when this stomp box is working its magic (although the circling alien spacecraft might be your first clue), and the first-class electronic on/off switch maintains incredible signal integrity in bypass mode. You can power the BUF300 with either a 9V battery or our PSU-SB DC power supply (not included).
Fear Not the Flange
Why should guitarists have all the effects-fried fun? Launch your bass into the outer limits with the Ultra Bass Flanger BUF300.
Specifications: • Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector: 1/4" TS • Output  impedance: 1k ohm • Power supply: 9VDC, 100mA DC regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelBUF300
  • Part Number248-6120
  • UPC4033653052450
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.85 lbs.
View similar products to the Behringer BUF300 Ultimate Bass Flanger Effects Pedal
in the Guitar & Bass Effects Pedals product category.
