248-6628_ALT_0
248-6628_ALT_1
Behringer BSY600 Ultimate Bass Synthesizer Effects Pedal
Brand:| Model: BSY600
Give your guitar or bass tons of extra low frequency tone with Behringer's BSY600 synthesizer effect pedal.
  • The ultimate bass synthesizer that reproduces the fat and powerful sound of classic analog synthesizers—at the touch of a footswitch
  • Real Sound Modeling (RSM) combines state-of-the-art DSP technology with sophisticated algorithms to emulate real acoustic environments
  • Take off with 11 cutting Saw, Square and Pulse synth waveforms, Control filter cutoff and LFO rate via expression pedal (not included)
  • Dedicated Mode, Decay/Rate, Resonance, Direct, Effect, and Frequency controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the Behringer PSU-SB DC power supply (not included)
248-6628
Weight: 1.5 lbs.
ORDER TODAY
Ships in 7-10 Business Days
List Price$74.99
You Save33%
$49.99
Part # 248-6628
The BSY600 is a high quality effect pedal that reproduces the powerful sound of classic analog synthesizers at the touch of a footswitch,
The only question is: Can your amplifier and PA system (and your audience) handle the massive bottom end that this pedal can turn out? The BSY600 is a sophisticated bass synthesizer tucked away in a compact stomp box that gives your guitar or bass tons of extra low frequency tone.
With 11 unique Square, Sawtooth and Pulse waveform modes to choose from, the BSY600 provides a veritable truckload of classic synth sounds. Simply select a mode setting and dial in the sound you want with the effect, resonance, decay/rate, and frequency knobs. Use the Direct knob to mix in the desired amount of your original signal, and you're off and running.
The integral Real Sound Modeling (RSM) processor enhances your bass or guitar's tone for truly rich sound quality. Also included, at absolutely no extra charge, is a genuine blue LED that shows power status and battery condition, as well as an electronic bypass footswitch, which maintains excellent signal integrity. You can power the BSY600 with Behringer's PSU-SB DC power supply (not included) or a 9V battery.
Specifications: • Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector: 1/4" TS • Output impedance: 1k ohm • Power supply: 9 VDC, 100 mA regulated (sold separately) • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 (sold separately) • Power consumption: 30 mA • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelBSY600
  • Part Number248-6628
  • UPC4033653053112
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight1.5 lbs.
View similar products to the Behringer BSY600 Ultimate Bass Synthesizer Effects Pedal
in the Guitar & Bass Effects Pedals product category.
Customer projects that include: Behringer BSY600 Ultimate Bass Synthesizer Effects Pedal
