Behringer BOD400 Tube-Sound Overdrive Pedal
Brand:|Model: BOD400|Part # 248-6626
With the BOD400 you get an overdrive pedal that supports the entire frequency range of bass guitars, yes even 5 and 6 strings!
List Price$37.99
You Save34%
$24.99
Part # 248-6626
  • Get tube-like distortion, smooth sustain and super-fat tone
  • This BEHRINGER product has been designed to compete head to head with leading products on the market
  • Unique Balance control to blend between overdriven and dry bass sound for maximum punch
  • Dedicated Level, 2-band EQ and Gain controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the Behringer PSU-SB DC power supply (not included)
Behringer's overdrive pedal gives you rich tube-like distortion and smooth sustain. The Balance control allows you to mix the overdriven signal with your natural bass sound for superb clarity, punch and extraordinary character. That way you can add the perfect amount of tube-like tone, without sacrificing all of your precious low-frequency content
BOD400's overdriven tones range from a slight grind to the syrupy-thick sound of a tube stack just before meltdown. You also get exceptional tone sculpting, thanks to an onboard 2-band EQ, so you won’t have to worry about your low "B" getting lost in the mix.
The BOD400 offers more features than anything in its class—and it won’t hurt your finances! From its easy–to-use controls, to its noise-free On/Off switch, the bass overdrive BOD400 will keep you solidly in the zone.
Specifications: • Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector: 1/4" TS • Output impedance: 1k ohm • Power supply: 9 VDC, 100 mA regulated (sold separately) • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 (sold separately) • Power consumption: 30 mA • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelBOD400
  • Part Number248-6626
  • UPC736211843579
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.9500 lbs.
View similar products to the Behringer BOD400 Tube-Sound Overdrive Pedal
in the Guitar & Bass Effects Pedals product category.
