Behringer BO300 Classic Blues Overdrive Effects Pedal
Brand:|Model: BO300|Part # 248-6624
Whether you seek the warm, vintage tube-amp howl that defined the electric blues, or the searing, saturated distortion that can level a juke joint, the BO300 by Behringer can accommodate.
  • Get the tone of a vintage and bluesy tube amp in an effects pedal—anything from warm overdriven sounds to full-blast distortion
  • Offers you the warm sound known from classic tube amps to capture every nuance of your playing
  • Dedicated Level, Tone and Gain controls for awesome sound shaping
  • Blue status LED for effect on/off and battery check
  • Runs on 9V battery or the Behringer PSU-SB DC power supply (not included)
  • First-class electronic On/Off switch for highest signal integrity in bypass mode
They say you have to "pay your dues to sing the blues," but the Behrigner Blues Overdrive BO300 makes that a thing of the past. You get all the classic blues tones, from sweet and sassy to overtly obnoxious, with just a simple twist of the dial—and BO300 club membership can be yours for a song!
Create precisely the sound you want with the dedicated LEVEL, TONE and GAIN controls. A blue status LED tells you when it’s on or off, and you can run the BO300 on a 9V battery or the optional DC power supply (not included). Thanks to its top-quality on/off switch, you get pristine signal integrity in bypass mode.
Whether you make your home in either the Mississippi- or the Nile-Delta, your sound will be pure blues with the Blues Overdrive BO300. And you won't have to sell your soul to get one—the BO300 is so affordable.
Designed for use with guitar, bass, and keyboards.
Specifications: Input connector: 1/4" TS • Input impedance: 500k ohms • Output connector: 1/4" TS • Output impedance: 1k ohm • Power supply: 9 VDC, 100 mA regulated • Power connector: 2 mm DC jack, negative center • Battery: 9V type 6LR61 • Power consumption: 30 mA • Dimensions: Approx. 2-1/8" H x 2-3/4" W x 4-4/5" D (54 x 70 x 123 mm) • Weight: Approx. 0.73 lbs. (0.33 kg).
  • BrandBehringer
  • ModelBO300
  • Part Number248-6624
  • UPC4033653052337
  • Product CategoryGuitar & Bass Effects Pedals
  • Weight0.73 lbs.
View similar products to the Behringer BO300 Classic Blues Overdrive Effects Pedal
in the Guitar & Bass Effects Pedals product category.
